Has anyone used this product? - Router Forums
post #1 of 3 (permalink) Old 03-30-2012, 08:37 AM Thread Starter
First Name: Dick
Default Has anyone used this product?
Woodworker's Supply sells a product called a "robo sander". It is basically a sanding drum (comes in different sizes) that fits in your drill press. What makes it different is that it has a bearing on the botton of the drum and is used for pattern sanding. It works like a flush trim bit, except is is a sander. It seems like it would eliminate the possibility of tearout like that encountered when using a router to flush trim tricky or end grain. Has anyone used this and, is so, what do you think of it?
Dick
rbh11g is offline
post #2 of 3 (permalink) Old 03-30-2012, 10:51 AM
Gene Howe's Avatar
First Name: Gene
I've used it for a couple projects. It works fine. Saves some time.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 3 (permalink) Old 03-30-2012, 10:59 AM
Seenya's Avatar
First Name: Doc
I use them and like the results. They're perfect for working on patterns or just sanding in general.
Semper Fi,
Doc
Seenya is offline
Product Source Needed: OPG3 Tools and Woodworking 9 05-29-2011 10:20 PM
Look for a product with graphite reible Tools and Woodworking 9 02-21-2008 12:20 PM
