Shop built band saw project - Router Forums
post #1 of 33 (permalink) Old 04-02-2012, 12:51 AM Thread Starter
First Name: Chris
Default Shop built band saw project
So I have decided to bite off more than I can chew, and am going to try to build a band saw.
My current plan is to build a small band saw using an electric motor I got on ebay and some scrap wood I have lying around. The plan is to make the wheels out of 2x8 pine. So the wheels will be about 7" diameter.
Eventually, maybe I'll make 14" wheels and a bigger saw, but I think I better start small.
For the wheels, I will use some skate board bearings. they are 7/8" outer diameter with a 5/16" inner.
That is all I have right now ... thanks for looking!
Chris Curl is offline
post #2 of 33 (permalink) Old 04-04-2012, 02:29 PM Thread Starter
First Name: Chris
QUESTION - how fast does the blade in a band saw move?
I'm trying to determine the pulley ratio for the motor and the wheels, so if someone could look at their BS and let me know what RPM the motor runs and the sizes of the pulleys connected to the motor and the drive wheel, that would be great.
I looked at a RYOBI 9" BS at Home Depot, and it looked like the motor ran at 3000 PRM and the pulleys between the motor and drive wheel were pretty close in size, both about 2-3 inches in diameter. If anything, the motor pulley might be a little smaller than the drive wheel pulley.
I wonder if a 14" BS And a 9" BS both move the blade at roughly the same speed ... ?
post #3 of 33 (permalink) Old 04-04-2012, 05:45 PM
The Warthog's Avatar
First Name: Roger
You might want to consider a larger saw as being more forgiving. A 1/16" error on a 7" bandsaw is twice as bad as the same error on a 14" bandsaw. Besides, it won't be long before you begin to wish you had made a bigger saw.
According to my Band Saw Handbook, saws generally run at 2600 to 3100 feet per minute. Do your own math.
Cheers,
Roger
I'm not slow, I'm pacing myself!
Isaiah 44:13 Another shapes wood, he extends a measuring line, he outlines it with red chalk. He works it with planes and outlines it with a compass...
Usual kit: Table saw, band saw, dual base router and table, lathe, various saws, planer, sanders, and a multitude of hand tools.
The Warthog is offline
post #4 of 33 (permalink) Old 04-04-2012, 07:12 PM Thread Starter
First Name: Chris
that is exactly the kind of number i needed, thanks!
i am thinking about a bigger saw, but the bigger it is, the stiffer the shell will have to be, which is my concern (being a newbie). that and the fact that the motor i have is only 1/2 hp, so it might not be up to some of the tasks.
but i doubt i'll be re-sawing really big stuff any time soon. famous last words, right?
post #5 of 33 (permalink) Old 04-04-2012, 09:04 PM Thread Starter
First Name: Chris
it turns out the bearings are a tad large for a 13/16" hole, and a tad small for a 7/8" hole
i guess i can do the 13/16 and the make it a tiny bit larger with a file or some sandpaper. then the bearings will be nice and tight.
i am going back to thinking i'd like to do a 14" instead ...
for the wheels, i'm thinking about taking some 1x5 and 1x6 pine and gluing them together at 90 degrees to make the wheels, sort of like they do plywood with the grain perpendicular on different layers.
or would i be better off gluing together 2 pieces of 3/4" plywood?
post #6 of 33 (permalink) Old 04-05-2012, 12:45 AM
First Name: roger
Chris just a thought here have you looked at the woodgears.ca website and checked out his building of a band saw
cedarwood is offline
post #7 of 33 (permalink) Old 04-05-2012, 08:00 AM Thread Starter
First Name: Chris
yes i have. even though i'm 51 years old, i want to be that guy when i grow up!
post #8 of 33 (permalink) Old 04-05-2012, 05:41 PM Thread Starter
First Name: Chris
i picked up a piece of 2'x2' 3/4" BC ply today - $7.63
i should be able to make 4 circles that will, after making sure they are perfectly round, be a little under 12" diameter.
so i am working towards having an 11 3/4" band saw i guess ...
i am going to start extremely simple with the support structure for it and refine it as needed until it is stiff enough for my needs. i won't be re-sawing thick stuff any time soon.
post #9 of 33 (permalink) Old 04-05-2012, 07:00 PM
I will be interested in watching your project as you progress.
To be candid, though, I cannot see the point in building a "T model Ford" (with the risk involved) when there are many "small sedans" available on Craigs List....
If you are building it just to say "I did it" - I can relate to that also.
First, make sure what size you want to end up with. This is not something you can change in mid-stream.
Sydney, Australia
jw2170 is offline
post #10 of 33 (permalink) Old 04-05-2012, 08:40 PM Thread Starter
First Name: Chris
it is about 30% "i made it myself", about 70% "i'm a frugal SOB and money is REALLY tight right now", and 100% "i have more time than money"
Joke a Day bobj3 Lobby 4135 Today 11:58 AM
Plans for shop built dovetail jig. thecave Jigs and Fixtures 29 11-15-2012 12:57 PM
Shop built "miter" saw Chris Curl Project Plans and How To 11 03-24-2012 12:43 AM
Shop Organization Marco Tools and Woodworking 8 10-07-2011 06:57 AM
Shop built router lift? TanOak Table-mounted Routing 51 09-13-2010 02:17 AM
