Identification of clamps - Router Forums
post #1 of 5 (permalink) Old 04-04-2012, 12:25 PM Thread Starter
Country: Portugal
First Name: Patrick
Default Identification of clamps
Greetings from Portugal and thanks for the welcome message to a newcomer.
I have been interested in woodworking for most of my life and now in retirement have just picked up a DW 625E, initially to turn out some slatted sun shades. I have recently been gifted a Trend Router Table Insert Plate (RTI/PLATE) and a couple of clamps/guides which conveniently brings me to my query:
I attach pics of the clamps and wonder if any members can identify these and know how they should be used/mounted.
From the above it is obvious that I am new to routing but am keen to make the most of the DeWALT and look forward to any reply that may be forthcoming.
Patrick H is offline
post #2 of 5 (permalink) Old 04-04-2012, 03:54 PM
OPG3's Avatar
First Name: Otis
Patrick, immediately looking at your photos - I have no clue what purpose the clamp(?) is made for. Many styles and configurations of clamps are utilized in woodwork (also in metalworking, etc.) This looks well-made, but the photos do not include an application. This could possibly be a purpose-built clamp or part of something larger that it is merely a component of.
OPG3
Tweak everything!
OPG3 is offline
post #3 of 5 (permalink) Old 04-04-2012, 08:03 PM
MEBCWD's Avatar
Hi Patrick,
Welcome to the router forums.
I believe what you have is a set of corner clamps.
I think you need a square frame for the bottom clamp (picture 1) to push the 2 sides into the corner. Clamp 1 mounted to the jig and pushed into the corner, then locked down by the thumb screw. Clamp 2 is for the top and goes into the corner and the 2 arms go over the sides and draw them into alignment. The sprins apply pressure to the workpieces.
Just a guess!
Work safe, Have Fun, Cut some wood,
Edit:
I don't think the corner has to be square, could be round joint. could be barrel clamps, boat clamps
MEBCWD is offline
post #4 of 5 (permalink) Old 04-05-2012, 04:23 AM
Phil P's Avatar
First Name: Phil
Patrick, they're not clamps. They are SUVA-type pressure pads or hold-downs (called Shaw guards in the UK). They are designed to provide both guard and hold down functions on router tables, for example when you are machining. The SUVA guards on the deWalt DE6900 router table are very similar:
The springs are there to press the workpiece firmly against the table or fence (or both at the same time if you want to machine very small section safely, e.g. 1 x 1in stock)
Regards
Phil
Phil P is offline
post #5 of 5 (permalink) Old 04-05-2012, 09:45 AM
MEBCWD's Avatar
Regards
Phil
Looks like they would be better for hold downs than glue clamps!
Should be easy to make yourself and mount with T-track on fence or table.
MEBCWD is offline
Converting C Clamps Mike General Routing 23 07-26-2015 01:08 PM
Shop Made Toggle Clamps for Gav Stefang Jigs and Fixtures 40 02-04-2011 05:38 AM
C clamps w/ball handle JerryPat Tools and Woodworking 2 01-16-2011 07:29 PM
Toggle Clamps (Update) Pop_pop1 Table-mounted Routing 1 08-29-2005 06:52 AM
T Track Toggle Clamps Pop_pop1 Table-mounted Routing 4 07-29-2005 02:22 AM
