Saw & Bit cleaning - Router Forums
post #1 of 16 (permalink) Old 04-08-2012, 03:21 PM Thread Starter
First Name: Rex
Red face Saw & Bit cleaning
Have not found a usable solution for cleaning tools, saw blades, router bits, wood
plane irons, etc.
Must remove resin, caking, rust, etc.
Would appreciate your help.
Rex
rex wenger is offline
post #2 of 16 (permalink) Old 04-08-2012, 03:35 PM
Seenya's Avatar
First Name: Doc
I use denatured alcohol for resin and such. I'm sure there are many things that will work but DN is probably the cheapest. As for rust I use Evaporust. It's safe and has no harmful fumes like Naval Jelly.
Semper Fi,
Doc
Seenya is offline
post #3 of 16 (permalink) Old 04-08-2012, 05:53 PM
Welcome to the forum, Rex
Thank you for joining us.
Sydney, Australia
jw2170 is offline
post #4 of 16 (permalink) Old 04-08-2012, 09:16 PM
I haven't tried it yet but the videos I've seen for the Trend cleaning solution look pretty good and it's not expensive.
post #5 of 16 (permalink) Old 04-09-2012, 01:26 AM
Spray on oven cleaner, Rex. Place your blade or other tool in a steel baking tray, spray oven cleaner on it...best to do it where you have good ventilation, Wait a couple of minutes, give it a a quick scrub...I use and old BBQ brush...and rinse it off.
That's it.
I usually give the tools a shot of WD-40 afterwards for a little rust protection.
(Oven cleaner is usually Sodium Hydroxide based; lye, in other words.)
DaninVan is offline
post #6 of 16 (permalink) Old 04-09-2012, 08:48 AM
Default Simple Green
I've heard that Simple Green works well but haven't tested it myself.
bigmuddyriver is offline
post #7 of 16 (permalink) Old 04-09-2012, 08:32 PM
First Name: Steve
Rex - going along with Dan and his oven cleaner on this. Easy spray application, no dunking in solvent. I take the tools out in the middle of the yard and put them on a sawhorse and spray. Barely even have to scrub after soaking.
Steve from California
Steve B. is offline
post #8 of 16 (permalink) Old 04-09-2012, 10:08 PM
That's it.
I was going to try lye or oven cleaner too but then I read somewhere that those chemicals can doamage the bond between carbide particles. There are other alternatives so I stay away from them.
post #9 of 16 (permalink) Old 04-09-2012, 10:39 PM
I'm with Chuck on this one. Rockler has a concentrated cleaner, about 10$/qt which makes a gallon of cleaner. It is also reusable if you use it for a soak. I've had a bottle of CMT spray cleaner I use and the bottle is almost a year old. I just spritz a bit on a towel and wipe down the router bits before I put them away. In a pinch I have also used 409, ZAP, Mean Green or Fantastic.
Some time ago, I believe it was Freud, that published a caution about using caustic cleaners as it can attack the carbide and/or the brazing. I've got way to much money tied up in cutting tools to risk a few cents on the chance that Freud is wrong. Besides, at almost $5/can for oven cleaner, it is hardly cheap on a per use basis.
John Schaben
jschaben is offline
post #10 of 16 (permalink) Old 04-09-2012, 11:57 PM
mr500's Avatar
For me, SIMPLE GREEN is about KISS as you can get. It works!! Its cheap. Plus it wont eat away at the solder/glue holding on the carbide tips. When cleaning I DO NOT use a harsh stiff brush. I use a soft bristle like a tooth brush. Dont laugh it works HAHAHAH
One of the blade mfg's recommends it, but I cant remember where I read that article.
Problaby not good for the rust, but great on the buildup..
If you like your freedom...Thank a Vet!!
Been doing it too long to be doing it wrong!!
mr500 is offline
Sears Router bit description gary smyth Jigs and Fixtures 4 07-18-2011 12:38 AM
Sears router bit description gary smyth Router Bits - Types and Usage 4 07-01-2011 05:15 PM
Sears Router bit description gary smyth General Routing 1 06-30-2011 10:23 PM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Bit Broke: Bad bit or bad technique Spokaneman Table-mounted Routing 14 01-26-2009 04:57 PM
