variable space boxjoints - Router Forums
post #1 of 6 (permalink) Old 04-09-2012, 11:17 AM Thread Starter
First Name: Malcolm
Default variable space boxjoints
I make small boxes. Looking for a way to make variable spaced box joints that are very clean.
Malcolm Byrd is offline
post #2 of 6 (permalink) Old 04-11-2012, 10:31 AM
Ken Bee's Avatar
First Name: Ken
The PDF file below is a good way to achieve what you are after if I understand your question correctly. It doesn't show using the router but doing it with the router like the table saw method is much the same procedure.
When something is advertised as being foolproof there is always a better class of fool that comes along to prove them wrong.
Ken Bee is offline
post #3 of 6 (permalink) Old 04-12-2012, 07:01 AM
CharleyL's Avatar
First Name: Charley
You may want to Google " Lynn's jig ". There are many posts on it, both here and elsewhere. It uses a threaded rod to allow incremental spacing of your cuts. With the appropriate number of turns of the threaded rod all kinds of spacing patterns can be created using either a router table or a table saw.
Charley
Central North Carolina
CharleyL is offline
post #4 of 6 (permalink) Old 04-16-2012, 05:23 AM Thread Starter
First Name: Malcolm
Default variable spaced box joints
Man I hadn't thought of making the joints like that. I have tried some of these jigs like Incra where you move the fence a certain amount, but if the router bit is slightly under sized the joint is too loose. The PDF file shows cutting to fit the lid with a large straight router bit - I use that on my boxes, but to prevent tearouts at the end of the cut, I do a climb-cut carefully. Thanks for the information.
post #5 of 6 (permalink) Old 04-16-2012, 12:45 PM
Ken Bee's Avatar
First Name: Ken
Making joints for a box is only limited by your imagination you know. How about a combination of dovetails and box joints on each corner? Such as dovetail, box joint, dovetail, box joint, dovetail. How about box joint, very wide dovetail, box joint or dovetail, wide box joint, dovetail or even a vertical sliding dovetail at each corner?
I use mostly 45 degree miter joints reinforced with contrasting splines for my boxes, but am working on a jig to cut dovetails on my router table at any given place on the box corner to reinforce the miter joint. The plan for the jig originated from the March/April 2011 issue of Shop Notes or issue Vol. 20 Issue 116 if you will.
In other words just go crazy and re-invent the wheel or box as it were.
Ken Bee is offline
post #6 of 6 (permalink) Old 04-18-2012, 07:40 AM Thread Starter
First Name: Malcolm
Default box joint / dovetail combination
I make boxes with mitered corners with splines. Lately I used rosewood hardwood flooring for boxes. Can't plane or sand off the original finish so I leave it & plane from back side. Have to tape good side to another board to run through planer else get scratches.
Bunk Beds - Save Space Arash010 Tools and Woodworking 1 10-12-2011 12:17 PM
Bypassing Craftsman variable speed control emptyjay General Routing 13 02-14-2011 04:10 PM
Variable Speed Controlers Timberline Table-mounted Routing 4 08-27-2010 09:55 AM
Variable speed routers MichaelT General Routing 10 02-24-2009 12:46 PM
Anyone use the Porter Cable 7216 Omnijig ??? emailtim Jigs and Fixtures 8 03-28-2006 09:37 AM
