VinceWNWonders, A Great Tool - Router Forums
post #1 of 3 (permalink) Old 04-13-2012, 04:04 PM Thread Starter
First Name: Jerry
Default VinceWNWonders, A Great Tool
The drill arrived today and I tried it in the shop by sanding the profiles in the faces of a couple of picture frames that I am working on. The tool worked as well as I had hoped it would. If you need a tool that will allow you to get into those tight places, this is the tool for most of those needs. Vince says that his primary market is the "Turners" and for their need to sand inside of such things as bowls. I am not one of those type of woodworkers yet, but I have been needing to sand the faces of the picture frames that I make. These frames have profiles cut in their faces with the router and sanding in the profiles by hand is not a fun part of the construction of the frames, I think that Vince's drill and/or sanding device will take care of the issue.
Jerry
Colorado City, TX
Jerry Bowen is offline
post #2 of 3 (permalink) Old 04-13-2012, 07:52 PM
Store www.VincesWoodNWonders.com
I have a similar set to clean up the inside of the bowls cut in the template jig.
Sydney, Australia
jw2170 is offline
post #3 of 3 (permalink) Old 04-14-2012, 07:44 AM Thread Starter
First Name: Jerry
Hi James,
I did learn real quick not to overheat things when using the tool as the heat will cause the adhesive that holds the pads and/or sanding discs togethr to break down. This is not a problem or fault of the tool, just a matter of common sense when you understand what is happening.
Jerry
Colorado City, TX
Suggest a new tool prefix Mark Power Tool Manuals 11 03-09-2014 10:25 AM
Wooden Tool Chess bobj3 The Bargain Bin 0 07-08-2011 09:00 AM
The Marvel 3 in 1 tool from MLCS: base plate and table mount advice please loninappleton Table-mounted Routing 4 07-10-2010 08:32 PM
can't find rounding hand tool frankjay02 Tools and Woodworking 3 10-15-2009 10:43 AM
