help with compound angles - Router Forums
post #1 of 2 (permalink) Old 04-18-2012, 06:39 AM Thread Starter
Country: Ireland
First Name: Javier
Default help with compound angles
hi guys i am new in the forum and i need some help with a project i am working in a elliptic dome formed by a series of irregular hexagons frames (honey comb type). i am having troubles to calculate the saw settings for my compound angles from my data. i have the mitre angle between the struts and the inclination angle between them. for example struts A&B form an angle of 96.66 and each one has an inclination of 10.86 from a plane axis between them. i suppose i need a mathematic formula for it, any help will be very appreciated.
Javier.
jayasu1 is offline
post #2 of 2 (permalink) Old 04-22-2012, 07:22 AM
Phil P's Avatar
First Name: Phil
Originally Posted by jayasu1 View Post
hi am having troubles to calculate the saw settings for my compound angles from my data. i have the mitre angle between the struts and the inclination angle between them. for example struts A&B form an angle of 96.66 and each one has an inclination of 10.86 from a plane axis between them. i suppose i need a mathematic formula for it, any help will be very appreciated.
Hi Javier
There are a mumber of sites on the web with compound angle calculations on them I find this one interesting because it does the calculations for you, has some useful diagrammatic illustrations and gives some of the mathematical formulae used to make the calculations - so you can build your own spreadsheet if needs be - or alternatively you can just download their spreadsheet
Regards
Phil
Phil P is offline
compound miter angles gdemo Tools and Woodworking 4 11-23-2009 03:40 AM
Bosch 5412L 12" Dual Compound Sliding Miter Saw and T4B Folding Stand Combo CanuckGal Tool Reviews 8 07-24-2009 01:19 PM
Compound miter saw quandry homersaurus New Member Introductions 4 08-30-2008 11:26 AM
compound angle chart delroy33 Jigs and Fixtures 1 03-28-2005 05:31 PM
Compound Angles reible Tools and Woodworking 2 03-28-2005 01:34 AM
