crawlspace access door - Router Forums
post #1 of 6 (permalink) Old 04-19-2012, 10:24 PM Thread Starter
First Name: Edward
Default crawlspace access door
Hi my name is Edward and I would like to know how to build a ,crawl space door,. Since it is exposed to cold moist air on one side and heated air on the other it must be made as an ,exterior door,. Then I will use weather stripping to seal the cracks.
elc.fishing is offline
post #2 of 6 (permalink) Old 04-20-2012, 05:02 AM
Welcome to the forum, Edward.
Sydney, Australia
jw2170 is online now
post #3 of 6 (permalink) Old 04-20-2012, 06:36 AM
First Name: Jack
Generally they are made of plywood. Sometimes, pressure treated plywood. Once in a while someone will make one out of 2x4's and plywood.
Don't give it a lot of thought, the temperature and humidity difference does not seem to make much difference.
I guess I'm somewhat of an expert on crawlspace doors because I am a home inspector, and go into crawlspaces on a daily basis.
The damage I see is usually:
1. Loose or broken hinges.
2. Wood rot because the door was in contact with the ground (or mulch).
3. Age, and the weather finally got to it.
barking spider is offline
post #4 of 6 (permalink) Old 04-20-2012, 06:56 AM
rrj
rrj's Avatar
First Name: Bob
My crawl space door is made from plywood and painted, it is about 25 years old and still fine except I wise the hinges held up better. Mine has insulation tacked to the inside as the crawl space is heated, furnace is in the crawl space which is 4 foot in height. Think about framing it with 2x4's so you can insulate it better.
Bob
Lake Geneva, WI
rrj is offline
post #5 of 6 (permalink) Old 04-20-2012, 09:53 AM
Edward, I have to build a new door for my crawl space access and I am going to use 1/2" plywood and 2 x 4" pieces to frame it. I will take photos of this project and post them on the forums in the near future.
post #6 of 6 (permalink) Old 04-30-2012, 02:46 AM
mr500's Avatar
The one we made was out of Marine grade plywood and PT 2x4's. Galvanized fasteners. It looks as good as the day we put it in 3 yr ago.
If you like your freedom...Thank a Vet!!
Been doing it too long to be doing it wrong!!
mr500 is offline
Weatherwatch derek willis Show N' Tell 10 03-16-2011 07:21 AM
Crawlspace door Cochese DIY and Renovation 14 03-04-2011 03:24 PM
Weatherwatch. derek willis Table-mounted Routing 11 02-14-2009 03:41 AM
