how to make stickly type of shiplap? - Router Forums
post #1 of 2 (permalink) Old 04-23-2012, 10:31 AM Thread Starter
Default how to make stickly type of shiplap?
Can someone give me idea on how to make shiplap like sticky does using router?
zlzhao is offline
post #2 of 2 (permalink) Old 04-23-2012, 05:37 PM
The joints you show are tapered. I wouldn't recommend trying that but a standard rabbeting bit will cut the edges for the overlap. One side of the board is rabbeted face up, the other face down. The bit has to be set EXACTLY half the thickness of the boards. If you want to add the 45 degree angle at the mating edges you can use a 45 degree plunge chamfering bit for that (i.e. a 45 degree bit with no bearing at the bottom).
I need to make molding for drawer fronts stormbraceman Router Bits - Types and Usage 7 11-01-2012 06:40 PM
How to Make a Box learnexperience Tools and Woodworking 0 08-04-2011 10:30 AM
Sold: Porter Cable Speedmatic Type 1 Plunge sjroo Woodworking Classifieds 9 02-10-2011 06:17 PM
How to make a template accurate? Steve Blackdog Guide Bushings and Templates 4 01-02-2011 03:44 PM
Make a template to create a filler piece? Ric Naff Jigs and Fixtures 3 01-12-2006 07:56 PM
