What do you use to sand the edge of plywood? - Router Forums
post #1 of 9 (permalink) Old 04-23-2012, 05:34 PM Thread Starter
First Name: will
Default What do you use to sand the edge of plywood?
In my last project, my circular saw made the plywood edge very rough. I used sand paper and a holder to polish it manually. I thought of buying a random orbit sander, but I was afraid that it might be too strong for the plywood edge. What do you think? Thanks.
volunteers is offline
post #2 of 9 (permalink) Old 04-24-2012, 06:37 AM
First Name: Normand
When you cut plywood, you can try to have a better blade for less sanding and chipping, it's not expensive and worth it and always use it a lot, when it's to rough I use my palm sander and always finish by hand with a block and sand paper to keep it strait.
If you can find a better blade like I mention before, it may be faster to use it just to get rid of the rough ride and saving lot of sanding.
Hope this can help you.
thrinfo is offline
post #3 of 9 (permalink) Old 04-24-2012, 12:50 PM
AxlMyk's Avatar
You could make the cut slightly proud of the cut line, then use a compression bit to finish it.
AxlMyk is offline
post #4 of 9 (permalink) Old 04-27-2012, 04:45 PM
I wish they were all this easy. Get a router pattern bit with 3 flutes. That's a bit with the bearing about half way up. MCLS is ok. I prefer 1/2" bits.
Take a straight edge and clamp it to the top of the plywood sheet about 1/32" short of the edge. You can use clamps or double side tape. Shave the plywood edge with a router removing about 1/32". You will have a perfect edge with no tear out and not rounded over. Sanding is a no no. A good blade is not needed but makes the job easier.
AaronRC4 is offline
post #5 of 9 (permalink) Old 04-28-2012, 07:51 AM
CharleyL's Avatar
First Name: Charley
The best sander for board edges is an oscillating drum sander. It will keep the edge square to the board's surface as you sand the edge, but it would be better if you could improve your saw so you wouldn't need to sand or rout the edges very much, if at all. A good, fine tooth carbide blade is my first suggestion. A zero clearance insert is my second suggestion. The zero clearance insert holds the edges of the cut from lifting and splintering as the blade teeth exit from the wood.
If your saw is a table saw you can make an insert from wood to replace the existing insert in your saw, but make it without a blade hole. Then install this new insert in the table and then slowly raise the saw blade while it's running to cut a saw slot through the insert at the exact width and position needed by your saw blade. If the blade won't go low enough to do this you can install a smaller diameter blade of the same width to make this first cut and then replace it with your full size blade.
For a hand held circular saw you can also make a zero clearance insert type base. You will need a piece of thin plywood or lexan plastic the same size as the base of your saw (don't use plexiglass as it shatters easily). You can attach it to the base of your saw by bolting it in place using flat head screws with the bolts recessed into the insert base. One bolt toward the front and one toward the rear should be sufficient. You will need to manually retract the blade guard and raise the blade as far as possible for this installation. Once the insert base has been installed , you can plug the saw in and run it while plunging the blade slowly and completely through the new zero clearance insert base. Then release the trigger, let the saw come to a stop, and unplug it. Now you will need to mark a clearance area where the blade guard needs to swing down through the zero clearance base, but do not mark the front area where the blade teeth come up through the insert. Only mark for removal the area that is actually needed for the blade guard to operate freely. You may need to remove and re-install this zero clearance base a few times to be sure that you have marked only the area for the blade guard to move freely. Now remove the insert base and cut out this marked area. The accuracy of this cut is not really important as it's only to let the guard operate. The remaining hole should look like a rectangle with a 1-2 inch saw cut in the leading edge. Re-install the insert base, make certain that the blade guard operates freely and you can raise and lower the saw blade to it's limits without binding. You are now ready to use it. As the blade teeth rise up through the wood, both sides of the saw cut will be held down by this zero clearance base and the wood will cut cleanly with very little splintering.
My shop is small so I can't cut full sheets of plywood on my table saw. I use my circular saw with a thin kerf fine tooth carbide blade and one of these zero clearance bases with a straight edge guide to break down my sheets of plywood outside my shop, then bring the parts inside for final milling. The circular saw cut edges are just as smooth and straight as if I had cut them on my table saw and little, if any, sanding is ever required.
Charley
Central North Carolina
CharleyL is online now
post #6 of 9 (permalink) Old 04-29-2012, 12:58 AM
I built an "L" shaped sanding jig. The long leg is the part I hold down on the ply or mdf. On the short leg I attach sandpaper. This way I keep the edges square. Any power sander with a rubber pad under the paper will round the edges off.
This is the jig I use when I need to laminate something to the edge or when I need to butt two pieces together as when I am joining countertop.
post #7 of 9 (permalink) Old 04-29-2012, 01:47 AM
wbh1963's Avatar
I have had great luck planing the edges of plywood incredibly smooth. Learning how to do that was one of my first successful attempts at putting a plane to good use. This $10.00, made in India, Windsor Model 33 Plane from Harbor Freight worked better than the "new era" Stanley SB4 that cost twice as much.
The technique I figured out that works the best is to hold the plane at a 45 degree skew, but push it across straight (the material is cut by the same section of the blade.
doing it that way balances out the impact of layer interleaving and 'skewing' a blade cuts the amount of force required to sever the wood fibers being cut.
That's how I clean up plywood (and solid of course!) edges.
wbh1963 is flowing with the grain in Arlington, Washington, USA
A day without curls is like a day without sunshine!
wbh1963 is offline
post #8 of 9 (permalink) Old 04-29-2012, 01:57 AM
If you start with a sharp plywood cutting blade you should not need sanding. I use and highly recommend Freud red saw blades.
post #9 of 9 (permalink) Old 04-29-2012, 10:28 PM Thread Starter
First Name: will
I bought a Freud 60T saw blade and the cut is perfect now. I only need a little bit hand sand now.
I used a blue type to cover the cutting line, which made the result even better.
Thank you all for the suggestion.
plywood edge screwing gav Tools and Woodworking 7 02-11-2010 10:41 AM
MDO for table top ebbonk Table-mounted Routing 1 01-04-2010 07:53 AM
Help with veneer plywood edge profile magicman22 General Routing 12 10-10-2007 03:13 PM
Rabbeting 3/4" plywood edge WoodenShoe Table-mounted Routing 3 06-13-2006 01:15 PM
Routing edge on plywood Dimitri Guest General Routing 2 10-20-2004 02:34 PM
