Wax to prevent glue from sticking - Router Forums
post #1 of 11 (permalink) Old 04-25-2012, 03:50 PM Thread Starter
First Name: Kevin
Default Wax to prevent glue from sticking
Say you're gluing up some wood and you're using a wooden spacer to help hold the pieces in line. But you don't want the spacer to get glued in with the rest. What kind of wax do you apply to it? Can someone provide a link?
Thanks,
Kevin
kawisser is offline
post #2 of 11 (permalink) Old 04-25-2012, 04:01 PM
paduke's Avatar
Bol-Wax Gasket-007004 at The Home Depot
paduke is offline
post #3 of 11 (permalink) Old 04-25-2012, 04:04 PM
Wouldn't wax paper do the job? Between the project and the spacer I mean.
DaninVan is online now
post #4 of 11 (permalink) Old 04-25-2012, 05:03 PM
I agree with Dan. Wax paper is what I use. Including for applying countertop laminate.
You would want to be careful about using wax because it can interfere with applying finishes later unless you get any residue sanded completely off.
post #5 of 11 (permalink) Old 04-25-2012, 06:19 PM
RStaron's Avatar
First Name: Ron
I've used Johnson's paste wax on the spacers I made for my candy dispensers. I've had no problem with it. Just make sure to wipe all the excess wax off of the spacers. It's the same wax I use to wax my table saw top with.
A person can never have too many tools!
RStaron is offline
post #6 of 11 (permalink) Old 04-25-2012, 07:01 PM
paduke's Avatar
and the above link is for beeswax costs less than paste wax. rub finger on wax rub stick viola
paduke is offline
post #7 of 11 (permalink) Old 04-25-2012, 09:10 PM Thread Starter
First Name: Kevin
I never thought to use wax paper. Sounds easy enough to wrap my spacer in wax paper.
kawisser is offline
post #8 of 11 (permalink) Old 04-25-2012, 09:28 PM
BigJimAK's Avatar
Wax paper is also handy for keeping glue drip off of clamp shafts. I cut a roll in two on my bandsaw as a half-width is what I found useful most often.
BigJimAK is offline
post #9 of 11 (permalink) Old 04-26-2012, 06:44 AM
First Name: Gene
Originally Posted by paduke View Post
These wax gaskets also work good for intalling screws. Soft and a little goes a long ways.
LiLRdWgn is offline
post #10 of 11 (permalink) Old 04-26-2012, 07:52 AM
The Warthog's Avatar
First Name: Roger
What I do. Never thought to cut the roll in two. We were out of wax paper in the kitchen the other day, and I completely forgot I have a roll in the shed.
Cheers,
Roger
I'm not slow, I'm pacing myself!
Isaiah 44:13 Another shapes wood, he extends a measuring line, he outlines it with red chalk. He works it with planes and outlines it with a compass...
Usual kit: Table saw, band saw, dual base router and table, lathe, various saws, planer, sanders, and a multitude of hand tools.
The Warthog is offline
Finishing the way I see it! by Derek Willis. derek willis Woodworking Articles 0 02-28-2011 08:44 AM
Keeping Panel from sticking to Rail/Stile Joint groff5 Tools and Woodworking 5 03-01-2010 03:40 PM
Glue rh111 Lobby 6 10-12-2005 02:30 AM
Wax... for tools reible General Routing 0 01-13-2005 12:08 AM
