Straight Or Spiral Jointer Knives - Router Forums
post #1 of 10 (permalink) Old 05-01-2012, 02:01 PM Thread Starter
First Name: Jerry
Default Straight Or Spiral Jointer Knives
In regard to buying a new jointer, so far it appears that the straight cutting knives will be the best choice for my purposes, I would like to hear from anybody that has an opinion on the this subject.
Jerry
Colorado City, TX
Jerry Bowen is offline
post #2 of 10 (permalink) Old 05-02-2012, 11:20 AM
Carbide segmented head. Smooooooth, no matter what the grain pattern, direction or the size of the knots.
I have had the other two and wouldn't go back.
Just me two cents because you asked.
JimE
TN
blackemmons is offline
post #3 of 10 (permalink) Old 05-02-2012, 02:13 PM Thread Starter
First Name: Jerry
JimE, tell me more, what are you telling me in regard to straight or spriral cutting knives, I,m interested in what you are saying, don't tease me with just a smidgen of what you know, OK.
Jerry
post #4 of 10 (permalink) Old 05-02-2012, 07:20 PM
rwl7532's Avatar
First Name: Ralph
Are you referring to the Byrd sHelix heads?
http://www.holbren.com/spiral-cutterhead/
I think you are suggesting getting the Grizzly with the ordinary head and changing it out:
http://www.holbren.com/home.php?cat=471
I have been using this supplier:
http://www.shop.woodworkingmachinery...ic-Shelix6.htm
(prices include shipping)
rwl7532 is offline
post #5 of 10 (permalink) Old 05-02-2012, 07:28 PM
Bradleytavares's Avatar
First Name: Bradley
A spiral cutting knife slices or shears the grain in a diagional manner resulting in a smoother cut, whereas a straight knife will tend to scrape as a snow shovel does resulting in a less than high quality product. Rockwells door plane has offeres a spiral cutter for as long as I can remember (I'm 60 years old) and for the purpose of a smooth cut on door edges. Many high quality joiners like Powermatic,have offered the spiral for many years and for good reason. If it's available, you can afford the upgrade and desire a higher than average product consider the option that's available
Bradleytavares is offline
post #6 of 10 (permalink) Old 05-02-2012, 07:41 PM
Jerry
PM Sent.
post #7 of 10 (permalink) Old 05-02-2012, 08:38 PM
rwl7532's Avatar
First Name: Ralph
If I were to do it over, I would consider buying a 6" beater on Craigslist and then upgrading the cutter head with the Byrd sHelix.
rwl7532 is offline
post #8 of 10 (permalink) Old 05-02-2012, 11:03 PM
boogalee's Avatar
First Name: Al
Jerry
Colorado City, TX
A few years back i upgraded from a 6" jointer with straight blades to a Grizzly GO593 (discontinued) 8" with spiral cutterhead. I would not go back to straight blades. The spiral cutterhead leave a almost finish ready cut. If you chip one of the cutters you can rotate it (3 times) and continue on.
If you chip a straight blade you may be able to sharpen it or you will have to replace it. Replacing and adjusting the blades are a PITA.
Good luck on your choice.
Al
boogalee is online now
post #9 of 10 (permalink) Old 05-03-2012, 02:18 PM Thread Starter
First Name: Jerry
Thanks for the respoonse Al,
I did get the jointer with the spiral cutters and your comment is an encouragement Sure am anxious to get the jointer in the shop and up and running.
Jerry
Colorado City, tX
post #10 of 10 (permalink) Old 05-03-2012, 08:24 PM
Jerry, an article in Fine Woodworking also concluded that they are cheaper in the long run.
Looking For Advise On 'Changing Knives On PC Bench jointer Jerry Bowen Tools and Woodworking 5 04-13-2012 11:53 AM
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 09:09 PM
Setting Jointer knives jd99 Tools and Woodworking 13 10-28-2009 10:49 PM
When to use a straight bit or spiral? Nickbee Router Bits - Types and Usage 3 07-24-2008 06:08 PM
Installing jointer knives - Help - Old 4" Joe Lyddon Tools and Woodworking 4 10-20-2007 10:54 AM
