Delta 11-990 drill press older model question - Router Forums
post #1 of 12 (permalink) Old 05-05-2012, 01:07 AM Thread Starter
First Name: Kirk
Default Delta 11-990 drill press older model question
I just bought a used but good condition Delta 12" benchtop drill press. Everything works really well. No visable run-out or vibration. However, using my caliper, I noticed when I lock the depth ring to drill a 1" hole and then lower the chuck, it measure 1 3/64". So I tried setting it to 1 1/2" and it was 4.5/64" off. Is there a way to adjust the stop or return stop (not sure if I'm stating this correctly) so my gauge is coinciding with the desired depth?
braunthrax is offline
post #2 of 12 (permalink) Old 05-05-2012, 01:32 AM
rwl7532's Avatar
First Name: Ralph
Cover the scale with masking tape.
Draw the 'real' distances on it.
rwl7532 is offline
post #3 of 12 (permalink) Old 05-05-2012, 01:41 AM Thread Starter
First Name: Kirk
That would take quite alot of time to do. The scale is circular and an inch on the scale is like 2 1/2" or so (guestimating). But still, thanks for the work-around.
post #4 of 12 (permalink) Old 05-05-2012, 02:00 AM
rwl7532's Avatar
First Name: Ralph
Oh, one of those.
I was thinking it was a vertical stop like my Jet.
Then ignore the scale and just measure when setting up and then lock it accordingly.
rwl7532 is offline
post #5 of 12 (permalink) Old 05-05-2012, 09:00 AM
Honored Member
First Name: pat
"Is there a way to adjust the stop or return stop (not sure if I'm stating this correctly) so my gauge is coinciding with the desired depth?"
No!
Have studied this one.
In my view, depth stops are poorly designed, full of slop, never lock on long runs and rarely = the travel depth desired. (Note. the hole depth is a function of stock thickness; if it varies, so does the hole depth.)
Made a top-stop. The stud can be adjusted to + or - .001 or so and never loosens over any length of run. Whence the jam nut is tightened: That's it, no mo locomotion.
Quillman is offline
post #6 of 12 (permalink) Old 05-05-2012, 09:40 AM
Country: Ecuador
First Name: david
Even the depth stops on Bridgeport vertical milling machines are inaccurate.Always measure your travel and proceed accordingly.
dherbert is offline
post #7 of 12 (permalink) Old 05-05-2012, 09:41 AM
the easy way
http://www.amazon.com/iGaging-DigiMA...29376&sr=1-118
post #8 of 12 (permalink) Old 05-05-2012, 10:36 AM Thread Starter
First Name: Kirk
The top stop is a great idea. I'm just not sure how I would attach it to my press. I have a neighbor who is an engineer with a bunch of metal working machines in his shop, so I'm sure I can get something put together. Thanks for the input.
post #9 of 12 (permalink) Old 05-08-2012, 10:19 AM Thread Starter
First Name: Kirk
What is a good solvent to remove some light rust off the column of the drill press? I don't want to use anything that may damage it. I do want to properly maintain my (new to me) tools.
post #10 of 12 (permalink) Old 05-09-2012, 10:59 AM Thread Starter
First Name: Kirk
Seems some steel wool and some brake cleaner did the trick. Looks almost new.
Delta Floor Standing Drill Press @ Lowes k3usr The Bargain Bin 5 10-01-2010 07:33 PM
help with drill press pls. allthunbs Tools and Woodworking 20 08-05-2010 05:24 PM
Drill Press Update delirous26 Tools and Woodworking 2 02-16-2009 12:10 PM
Guide Bushing Holes and Drill Press cbsjoez1935 Jigs and Fixtures 2 10-08-2007 03:37 PM
