What is the advantage of Parallel Clamps? - Router Forums
post #1 of 35 (permalink) Old 05-08-2012, 12:02 PM Thread Starter
First Name: will
Default What is the advantage of Parallel Clamps?
The clamp like this one:
Amazon.com: Jet 70440-2 40" Parallel Clamp 2 Pack: Home Improvement
I know it has a bigger face to touch the wood, did I miss the major points? What is the advantage compared with regular F-Clamp and the following Pipe Clamp?
Amazon.com: Bessey BPC-34 3/4-Inch H Style Pipe Clamp: Home Improvement
The pipe clamp is cheap and exchangeable, I suppose it should be the most popular clamp. But I saw people used more F-clamps than pips clamps.
volunteers is offline
post #2 of 35 (permalink) Old 05-08-2012, 12:47 PM
Contributor of the Month
OPG3's Avatar
First Name: Otis
Will, the one word answer is, "Fixity".
Parallel clamps maintain.......parallel. Glue can actually act as a lubricant in glue-ups, and it is for this reason that parallel must often be maintained, but even parallel clamping must be done correctly. The shortest distance between any two points is a straight line - but even this can be seemingly compromised in some glue-ups.
OPG3
Tweak everything!
OPG3 is offline
post #3 of 35 (permalink) Old 05-08-2012, 07:44 PM
jlk103144's Avatar
Those are very nice, but also have a nice price tag.
I wonder if a setup using cauls and clamps might be just as good, but not cost as much?
jlk103144 is offline
post #4 of 35 (permalink) Old 05-09-2012, 05:18 AM
Jack Wilson's Avatar
First Name: Jack
For what it's worth, the Jet clamps are only 4 times more than the Bessys you've linked to, but you need to add in the pipe cost which may be near $12 for 40" black iron, now the clamp is about $25-$27 and suddenly the Jets are only twice as much. Sure its a lot, but then you get a lot more too.
http://www.amazon.com/Jorgensen-8048...6558418&sr=8-1 $50 each
Amazon.com: Bessey KRX2440 K Body REVO Fixed Jaw Parallel Clamp Kit Includes: 2-24-inch, 2-40-inch K Body Clamps and 2-KBX20 Extenders: Home Improvement Check out this deal, (2) 24", (2) 40", and (2) bar extenders, all for $150
I think a good set up is to have several of each type, the bar clamps are less expensive and interchangeable with different lengths of pipe so sure you want to have those available. Don't not get them, they can be great. But there is a time and place for the parallel bodies too.
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #5 of 35 (permalink) Old 05-09-2012, 06:04 AM
wbh1963's Avatar
Many thanks to Will for bringing the topic up and Otis and Jack for sharing their thoughts on the subject.
wbh1963 is flowing with the grain in Arlington, Washington, USA
A day without curls is like a day without sunshine!
wbh1963 is offline
post #6 of 35 (permalink) Old 05-09-2012, 08:09 AM
First Name: Chris
I think the price tag is NOT nice!
Chris Curl is offline
post #7 of 35 (permalink) Old 05-09-2012, 11:32 AM
MikeMa's Avatar
I just recently decided to gradually start switching out all my clamps for the Bessy Revos. Yes. They are expensive. They are worth every penny. There hold power and ease of far exceed anything I have previously used. Something I have quickly learned with clamps is that, like most anything else, you get what you pay for.
The 4 pack with extenders from Amazon is a good deal, and in fact I will be discussing it with SWMBO this evening.
MikeMa is offline
post #8 of 35 (permalink) Old 05-09-2012, 05:01 PM Thread Starter
First Name: will
I bought that two JET 40'' clamps with $60 from Amazon when they were on sale.
I wonder how JET clamps compare with Bessy? The Amazon Bessy deal looks great.
post #9 of 35 (permalink) Old 05-09-2012, 05:05 PM
Country: Netherlands
do nbot know
TimmerwerkTV is offline
post #10 of 35 (permalink) Old 05-09-2012, 06:57 PM
MikeMa's Avatar
I have heard really good things about the Jet clamps, and are at least as good as the Bessey's. I do believe the blocks on them are a little bit bigger. The only reason I went with Bessey over Jet is I can get Bessey clamps often on sale at woodcraft and Lowes, where no where local sells the Jets.
As an FYI, I did end up taking advantage of Amazon's deal. If you don't mind waiting 5-8 days you can get shipping free. Thank you Jack for pointing that out.
MikeMa is offline
Converting C Clamps Mike General Routing 23 07-26-2015 01:08 PM
Shop Made Toggle Clamps for Gav Stefang Jigs and Fixtures 40 02-04-2011 05:38 AM
C clamps w/ball handle JerryPat Tools and Woodworking 2 01-16-2011 07:29 PM
Toggle Clamps (Update) Pop_pop1 Table-mounted Routing 1 08-29-2005 06:52 AM
T Track Toggle Clamps Pop_pop1 Table-mounted Routing 4 07-29-2005 02:22 AM
