Rigid Oscillating Edge/Belt Spindle Sander EB4424 - Router Forums
post #1 of 14 (permalink) Old 05-17-2012, 08:58 PM Thread Starter
mr500's Avatar
Default Rigid Oscillating Edge/Belt Spindle Sander EB4424
Well Im off tomorrow to pick up one of these combo units. Anyone out there have any concerns with them?
It has awesome reviews so I thought it would be a good to pick one up.
If you like your freedom...Thank a Vet!!
Been doing it too long to be doing it wrong!!
mr500 is offline
post #2 of 14 (permalink) Old 05-17-2012, 09:17 PM
Jack Wilson's Avatar
First Name: Jack
Hello Mike, I have one, one of the first things I wanted to do with it was order MUCH finer grit sleeves and belt. I was only able to find sets of sleeves for the 3 smallest spindle sizes, but at the time that was sufficient, and I didn't look any farther. The 80 grit it comes with, even with the oscilation leaves a very rough finish. Otherwise I have been happy with it so far.
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #3 of 14 (permalink) Old 05-17-2012, 09:47 PM
First Name: Dick
Mike,
I've had mine for the past 4 or 5 years, and use it on a regular basis. The only problem that I have had is to replace the switch twice. Dust has a tendency to get in and burn the contacts. I haven't looked at the new ones lately, and they may have put a dust shield on the switch to cure the problem. My sander has been used many hours and has proven itself to be a good unit----especially for the price.
Dick
dick in ia is offline
post #4 of 14 (permalink) Old 05-17-2012, 10:10 PM
kp91's Avatar
First Name: Doug
Great unit. Higher grits are available from HD or HF.
Exceptional value.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #5 of 14 (permalink) Old 05-17-2012, 10:48 PM Thread Starter
mr500's Avatar
I think its a nice deal as well. Ill look at stocking up on some sleeves/belts. I would think thats all standered stuff...
Someone on here had said something about the hold down bolt (??) being self tightening so you must loosen it up after each use??
Ill keep and eye on the switch.
Thanks so much
mr500 is offline
post #6 of 14 (permalink) Old 05-18-2012, 12:40 AM
papawd's Avatar
First Name: warren
I have one and after about a year now thinking of selling my old belt sander as all I use is the Ridgid. Belts and sleeves have been found at Home Depot from time to time
papawd is offline
post #7 of 14 (permalink) Old 05-18-2012, 02:54 AM Thread Starter
mr500's Avatar
Yeah I do not own a belt sander. Only one I have is an orbital 6in 8 hole. I think this will be a good addition to my tool cart lol..
M
mr500 is offline
post #8 of 14 (permalink) Old 05-18-2012, 06:54 AM
Country: Ecuador
First Name: Michael
I've had mine for 2 years and really like it. The only problem I have is with the hold down nut. I keep thinking about making a wrench to loosen the thing so I don't tear up the plastic/rubber knob. As a suggestion try to use the HF coupon and save a little. I had to go to two HDs but the second one did honor it.
MichaelD is offline
post #9 of 14 (permalink) Old 05-18-2012, 08:11 AM
First Name: del
The only thing i do is leve the nut loose after using. If not it will get so tight you will not be able to get it loose. The first one the nut froze so tight not ever a pipe wrinch could get it off. I took it back and they gave me a new one. just a tip. Regester it for a life time warrenty also. It is a nice unit i have had mine for yrs now and it works good.
del schisler
port st. lucie, florida
del schisler is offline
post #10 of 14 (permalink) Old 05-18-2012, 08:41 AM
Gene Howe's Avatar
First Name: Gene
I've had mine for several years and use it quite frequently. It's great for truing up patterns and smoothing curves on band saw boxes.
The HD near me only stocks sleeves from Ryobi and they are all 80 grit.
Since some of my boxes are 5 1/2" thick, the 4" capacity was a problem. To solve this I had a 2" extension milled and now buy 6" sleeves from Supergrit. The also have the rubber drums in the correct sizes. The belts I just buy from ACE.
My knob sometimes get's pretty tight but, never so tight I can't get it off by hand. I don't tighten it really tight in the first place. Sometimes, the sleeve will creep, then I just tighten a little bit more.
Gene Howe
Snowflake, AZ
Gene Howe is offline
Ridgid Belt/spindle sander EB4424 kp91 Tool Reviews 18 04-28-2015 10:06 PM
Sander EB4424 Oscillating Edge Belt / Spindle Sander blboyd Ridgid Manuals 0 03-10-2011 08:31 AM
JET 708404 Oscillating Spindle Sander Dejure Tool Reviews 8 08-16-2010 03:24 AM
jet model 22-44 oscillating sander R B Battleford Tools and Woodworking 2 05-19-2010 09:24 AM
New Bandsaw and Oscillating Sander GoonMan Lobby 3 11-15-2008 12:40 AM
