Picture of my Drill Press recently finished - Router Forums
post #1 of 6 (permalink) Old 05-20-2012, 01:21 PM Thread Starter
Country: Germany
First Name: Rhett
Default Picture of my Drill Press recently finished
Hi all
You cant take out what you don't put in eh? So as promised a month or two ago as I was researching my design for the drill press i was about to make, here are the images of what I ended up building.
Stability was rated as important by both all the threads I read on the topic and from my own perspective. So I went for two sheets of 19mm / 3/4 inch furniture quality ply wood.
Size is always a tricky question, especially in my very small shop. I ended up going for the dimensions of 610mm wide by 460mm deep. I cut a semi circular recess in the back of the board to accommodate the drills stand ensuring that I still had easy and un-compromised access to the winder handle for the drill press.
The use of all of the Incra T-Tracks, rules and stops and hold downs was consistent with my Router table fittings so I can use and swap the hold downs and stops across both tools as needed. Here in Germany, we are not so well off in having a local Home Depot to pop down to that has all of this gear. Internet shopping would have had to be my choice and so I figured stick to what I know and get Incra stuff from the local distributor and in some cases from the USA.
Mounting the table to the Drill press was both simple and tricky. My drill press has four diagonal T-slots in the cast iron drill table so it was a matter of locating where the slots were in respect of the overall table and then drilling the two holes counter-bored for the 10mm coach bolts to secure it. If I need to remove the table, then its an easy process of just undoing the two bolts with a socket and bingo its off.
I have a square sacrificial piece of 6mm ply offset to the drills centre so that I can flip it front to back and of course over to give me plenty of room to use the maximum amount of space on the sacrificial board.
I would like any tips on how to finish it? Obviously it needs a varnish of some kind. I have also read of applying a a wax finish to the top for ease of movement of pieces being drilled as well. Tips gratefully received.
OK Hope these pics hels someone else out there about to head down a similar road.
Warm Munich regards to all
Rhett
Name:	Drill Press 1.jpg
Name:	Drill Press 2.jpg
Name:	Drill Press 3.jpg
Name:	Drill Press 4.jpg
Name:	Drill Press 5.jpg
Name:	Drill Press 6.jpg
RLego is offline
post #2 of 6 (permalink) Old 05-20-2012, 06:42 PM
Sharp(nice) looking rig.
I'd just coat it with shellac, quick to dry, several coats with quick sanding to smooth out, easy to refinish.
TomE is offline
post #3 of 6 (permalink) Old 05-20-2012, 09:00 PM
papawd's Avatar
First Name: warren
Nice job
papawd is offline
post #4 of 6 (permalink) Old 05-20-2012, 11:55 PM
First Name: Geoff
Nice job on the table.
I hope my attempt turns out as well.
Regards
Geoff
geoff_s is offline
post #5 of 6 (permalink) Old 05-21-2012, 02:40 AM
switchedoff's Avatar
Send a message via Skype™ to switchedoff
Nice job, I would try a polyurathane maybe
switchedoff is offline
post #6 of 6 (permalink) Old 07-12-2013, 03:13 PM
Great job, I am looking for ideas for a table I am going to build soon.
schor is offline
Drill DP15501 15" Drill Press allthunbs Ridgid Manuals 2 01-18-2018 12:13 AM
Finishing the way I see it! by Derek Willis. derek willis Woodworking Articles 0 02-28-2011 08:44 AM
All thread for router skiis rstermer Jigs and Fixtures 99 08-09-2009 10:54 AM
Welcome to "Show N' Tell" Mark Show N' Tell 0 08-17-2005 04:55 PM
