The Problem With The Incra Miter Gauge - Router Forums
post #1 of 17 (permalink) Old 05-28-2012, 03:55 PM Thread Starter
First Name: Jerry
Default The Problem With The Incra Miter Gauge
The Incra Miter Gauge is an outstanding tool and I have been impressed with it until now. The problem that I am having with it is not necessarily the fault of the gauge. The problem that I am referring to is that in order to get the most out of it is that in the end the user, in my case, myself, has to do the final calibration and if that is not done perfectly, the real accuracy of the gauge is lost. I have mine calibrated so that all of my 45 degree cuts are as good as I would ever like them to be, but when cutting six workpieces at 30 degrees, the result is off just enough to tell me that either the gauge is not perfectly calibrated, or the gauge is not as accurate as I have been led to believe that it is.
The slight error that I am talking about, is admitedly slight, but it does exist and I want a miter gauge that is dead on, this one might be, but the issue of calibration rests with me and it's giving fits.
Jerry
Colorado City, TX
Jerry Bowen is offline
post #2 of 17 (permalink) Old 05-28-2012, 06:26 PM
Jerry, you can use a plastic drafting triangle to set your angle and then calibrate your miter gauge so it is exactly on. Once the calibration is set you should have no future problems.
post #3 of 17 (permalink) Old 05-28-2012, 10:00 PM
First Name: Wayne
I'll agree with Mike. Once it is set up correctly it should be on. I double check my miter gauge when making cuts. I have set ups for 45* 30* and 22.5* i use. Mine is not an Incra but hoping to buy one soon. I have found that cutting a setup jigs is the best way to go. Mine has not left down yet.
WayneMahler is offline
post #4 of 17 (permalink) Old 05-29-2012, 08:03 AM Thread Starter
First Name: Jerry
This is addressed back to Mike as well as any one else that says that their gauge is dead on. Are you saying that if your miter gauge is set correctly that when you cut the six parts at 30 degrees that if the cuts are made with the the parts firmly again the fence that e all six joints are absolutely tight? Then with that calibration your 45 degree cuts are also dead on.
Right now, when I make the cuts, I am gettin an error on .003" when the parts are four inches in length. That is close, but not dead on. When I make 45 degree cuts I can decern no error at all.
Jerry
post #5 of 17 (permalink) Old 05-29-2012, 08:08 AM
cagenuts's Avatar
Country: South Africa
First Name: Hilton
Send a message via Skype™ to cagenuts
Jerry, watch this video.
How do you know the initial cuts are indeed 45 degrees? Even the Wixey digital gauges have a margin of error. So again, it's best to follow the linked video, make the appropriate adjustments until you get it correct. It then doesn't matter what any gauge is telling you.
cagenuts is offline
post #6 of 17 (permalink) Old 05-29-2012, 12:32 PM Thread Starter
First Name: Jerry
Hilton,
The way I conclude that my cuts are at 45 degrees is when I cut a picture frame and clamp it up with a clamping strap and the joints fit perfectly with no gaps at all, to me this dead on at 45 degrees, am I missing something. As to the Wixley digital gauge, it's a cute gadget, but a far cry from a precison instrument, and was a waste of money in regard to being used for any precision work.
Jerry
post #7 of 17 (permalink) Old 05-29-2012, 12:56 PM
Jerry, you are worried about .003" when working with wood? Breath on it and it will change to be perfect. Once the gauge is calibrated by using a triangle it will be dead on in all positions. You should check out the Betterley Una-Gauge here: Betterley Industries
post #8 of 17 (permalink) Old 05-29-2012, 02:25 PM Thread Starter
First Name: Jerry
Hey Mike,
Maybe you have found the problem, maybe I'm to picky, but to me .003 inch gap that you can see light through is, or has been, dut to my ingnorance, unexceptable. I just order an Osborne miter gauge and want see how it works compares to my Incra gauge, if I still have the same error with the Osborne gauge, I will know than my expectations are just greater than what is possible with these high end miter gauges.
Jerry
post #9 of 17 (permalink) Old 05-29-2012, 03:25 PM Thread Starter
First Name: Jerry
Getting back to Hilton's suggestion to watch the video about tuning the miter gauge. I had watched that video before posting my remarks about the Incra Gauge. After makeing the twelve 30 degree cuts on six workpieces and seeing that the miter gauge was not spot on, the error was extremely small but did exist. The question then becomes, how does one get that last thousandth of an inch or so error out of the setting. Yes, you sure know that error exists, but how can you adjust it out without using some trial an error method. That's the rub as far as I can see. I cannot detect any error with my machinist square wieh checking 90 deree cuts, but error does exist when doing the drill as shown in the video, but thanks for the suggestion anyway.
Jerry
post #10 of 17 (permalink) Old 05-29-2012, 04:00 PM Thread Starter
First Name: Jerry
Mike,
Can you tell me a little more about the triangle that you are referring to, I am not familiar with one and would like to know more about one as to it's accuracy, it's rigidacy etc. If you read this, I hope that you will respond, also, is there a way to contact you directly through this forum or some other way, you seem to stay on top of the posts that I am making and you also seem to be pretty savvy about woodworking.
Jerry
Kreg Miter Gauge vs. Incra Miter Gauge Jerry Bowen Tools and Woodworking 8 06-04-2012 09:58 AM
INCRA 1000HD Miter Gauge for Router Table Geordie99 Table-mounted Routing 3 12-30-2011 11:05 PM
Use an old miter gauge with t-track loninappleton Table-mounted Routing 10 05-25-2011 08:17 PM
Miter gauge roofner Tools and Woodworking 8 04-07-2011 12:20 AM
PC plunge router depth gauge problem codgerbill Portable Routing 5 03-25-2010 09:50 AM
