The Incra I-Box Jig - Router Forums
post #1 of 2 (permalink) Old 07-16-2012, 07:59 PM Thread Starter
First Name: Frank
Default The Incra I-Box Jig
(INCA I-BOX JIG) I posted earlier asking about this jig. It was quite new then. I am now asking, has any one tested and used this JiG? The research is favorable for the jig. I am not a real pro by any means at woodworking, but enjoy working with wood. So I am very interested in the the I-BOX JIG. I know it is a bit expensive, but for what I am trying to do, I think it may be the way for me to go.
Tagwatts1 from Utah
Remember to eat your desert first as you may die before your food arrives.
Tagwatts1 is offline
post #2 of 2 (permalink) Old 07-17-2012, 06:19 AM
cagenuts's Avatar
Country: South Africa
First Name: Hilton
Send a message via Skype™ to cagenuts
If you use it on a table saw, then the calibration is once off but you are limited to the widths your dado blade can be configured for.
If you use it on a router table, then you will need to calibrate every time you change the bit diameter. Upside is that it will work with every conceivable straight/spiral bit, be it metric or imperial.
If you have a router that is attached to a table saw extension wing then the miter slot may be too far away.
Otherwise, just go for it.
cagenuts is offline
My first box dkneifel Show N' Tell 19 02-08-2016 09:10 AM
Discussion About The Incra Dovetail Jig Jerry Bowen Tools and Woodworking 11 07-01-2012 05:13 PM
Hinge mortising question Dalec Jigs and Fixtures 8 03-02-2009 07:17 AM
Oak Park box jig jtfoodguy Jigs and Fixtures 14 02-16-2009 10:35 PM
Rousseau table and box joint jig pitonyak Jigs and Fixtures 3 02-26-2007 12:18 AM
