Garage/Workshop Cooling - Router Forums
 1Likes
post #1 of 27 (permalink) Old 08-10-2012, 07:11 AM Thread Starter
Default Garage/Workshop Cooling
I live in Phoenix, AZ. Summers get real hot (100+). Would welcome any ideas on how to cool down my garage/workshop so that I can get some work done in the summer months. Central airconditioning is not an option.
joevm is offline
post #2 of 27 (permalink) Old 08-10-2012, 09:44 AM
Guest
First Name: Robert
45 average morning humidity and 18 percent average afternoon percent May - September says swamp cooler. I'll venture to say they are probably real common in the Phoenix, AZ climate.
57759 is offline
post #3 of 27 (permalink) Old 08-10-2012, 09:56 AM
giradman's Avatar
First Name: Dave
Well, if you want AC & heat + a major investment, a mini-split is what we selected for a porch remodel - the Mitsubishi Mr. Slim shown below; the smaller unit is on the brick wall of the porch as shown; the conduit goes below the floor to the main unit under the porch floor - with a studded wall the conduit contents could be hidden. The porch is about the same size as your shop but w/ a standard height ceiling.
giradman is offline
post #4 of 27 (permalink) Old 08-10-2012, 10:02 AM
GRLevel3's Avatar
First Name: PoppaRob
Never been to AZ, but in UT we go almost every year, they use the swamp coolers and they are cheap, well when I thought I might try one in AR which will not work, lol
Did quick look at HD and found this one, not what you might want but its a start, cheap and 250 sq ft of cooling, self contained, did not look at lowes
500 CFM 3-Speed Portable Evaporative Cooler for 250 sq. ft. (with Motor)-EC302 at The Home Depot
GRLevel3 AKA Poppa Rob
GRLevel3 is offline
post #5 of 27 (permalink) Old 08-10-2012, 10:36 AM
Guest
First Name: Robert
Yes, the correct name is Evaporative Cooler and one problem with the Portable Evaporative Cooler is they are often used in a space with the windows closed and as they operate the humidity percent increases and the unit becomes , well , not so Evaporative with the air becoming more saturated and uncomfortable in many instances.
If one or two of the portables were to be installed in window openings for outdoor air intake then they may very well work in the Phoenix climate.
57759 is offline
post #6 of 27 (permalink) Old 08-10-2012, 11:31 AM
curiousgeorge's Avatar
First Name: George
I live in Texas and yesterday was 108*. I just bought a 110V, 13k BTU portable AC/heater/dehumidifier combo unit for around $500 for my 400 sq. ft. shop/garage. I looked at the split minis but I could have, literally, built a new shop for what those things cost (around $4K installed). I have only had it for about a week, but it seems to make a huge difference. The key is insulation. I also added extra insulation to the attic over the garage as well as putting weather stripping around the garage doors. All of this will pretty much seal off your shop, so you will need some kind of air filtration to keep the dangerous sawdust down as well as circulating the air. As I said it was 108* yesterday and the shop was a "comfortable?" 85 to 90*.
Edited: I should have said that the shop was 85 to 90 without the AC unit being turned on due to the insulation and weather stripping. That is a significant amount compared to outside temp.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is online now
post #7 of 27 (permalink) Old 08-10-2012, 12:11 PM
"...and the shop was a "comfortable?" 85 to 90*."
George; look into raising the Albedo effect of your roof colour. You can achieve a significant drop in interior temperature.
http://whiteroofproject.org/wp-conte...an-climate.pdf
DaninVan is offline
post #8 of 27 (permalink) Old 08-10-2012, 01:16 PM
First Name: Scott
I live in Northwest Phoenix and I understand your pain. Evaporative coolers would not work too well in the summer months as our humidity is up. I had the same problem as you and got a Koolfront air conditioner, which is on wheels and vents through a four inch hose which you put out your window. You will also need an air filter to remove all of the sawdust that will fly around. If you do not get an air filtration system, the air conditioning coils will quickly get plugged up. I got an air filtration system that hangs from the ceiling so it does not take up any of my limited floor space.
CactusRoper is offline
post #9 of 27 (permalink) Old 08-10-2012, 02:31 PM
MAFoElffen's Avatar
I'm also thinking insulation. Most people don't think about needing much insulation in a desert region... but it also helps to keep "hot" out and "cold" in.
From and my parents still live in Eastern Washington, a little thought of desert region, where temps are not uncommon to get above 120 degrees. I can still remember putting insulation in a building when it was 128 degrees outside (never measured it inside). Not a real pleasure when you're sweating and all those loose insulation fibers stick to you. ::scratch::scratch::
MAFoElffen is offline
post #10 of 27 (permalink) Old 08-10-2012, 02:55 PM
Default Think Pink
I'm so glad I'm retired and not having to do that anymore! Makes my skin itch just thinking about it.
The worst part is taking old insulation out, full of rodent droppings and urine, not to mention the odd mummified rodent corpse.
DaninVan is offline
Cooling the Shop BernieW Woodturning and Lathes 9 05-08-2018 07:24 AM
Saw dust plugging cooling slots Astrowood Table-mounted Routing 33 12-31-2009 10:02 AM
cooling system for my shop Glenmore Special Needs Woodworking 6 08-13-2009 09:39 PM
