Planer - Router Forums
post #1 of 3 (permalink) Old 12-22-2006, 06:04 PM Thread Starter
Hamlin's Avatar
First Name: Ken
Default Planer
After purchasing my planer 'bout a yr ago, I've been considering on what type of stand/table to mount it to. I decided to the lazy route. I've mounted mine to a Ridgid miter saw stand. It's simple and easy to move around and store out of the way. If space is an important issue with you as it is with me, you may consider this option.
Ken
"A VETERAN"
Hamlin is offline
post #2 of 3 (permalink) Old 12-23-2006, 12:36 AM
ShopNotes has an excellent plan for a planer stand. I intend to build one this winter and my planer ended up on a Shop Fox tool stand for the time being.
post #3 of 3 (permalink) Old 12-23-2006, 03:21 AM
RustyW's Avatar
First Name: Rusty
Dont forget about the weight of the planer. My work area is prety small, so most stands or fixtures need to be multi-purpose. I recently got a planer and built a rolling stand for it and my miter saw. With the ability to lock one on the top while the other is stored underneath. But the "portable" planer is so darned heavy, it stays on top and the saw usually gets placed on sawhorses when needed.
I replaced my evaprotive cooler last year. But with all the experience I had with repairing the old one. I've had ideas of building a "flip" stand using a hardend steel swamp cooler axel and bearings.
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
Planer Jigs.... challagan Tools and Woodworking 8 04-05-2013 10:52 PM
used planer reikimaster Tools and Woodworking 19 04-22-2012 02:12 AM
Thin stock to 1/8 inch on Planer ACV Tools and Woodworking 6 10-21-2007 11:13 PM
Jointer? Or Planer? Which one first? reikimaster Tools and Woodworking 26 09-27-2007 01:38 PM
I need help! Dewalt Planer Question FordPrefect Tools and Woodworking 4 12-12-2004 12:19 PM
