Bosch GTS 10XC and Dados thanks RCP16 - Page 3 - Router Forums
 6Likes
post #21 of 35 (permalink) Old 06-16-2014, 07:30 AM Thread Starter
Originally Posted by ibonneau View Post
Hello,
Been following this ever since I thought of buying the GTS 10XC and now that I have, I was wondering could I just get the inner washer (the one with the 30mm shoulder) replaced with the 4100 model - so that I could use a dado set ? perhaps I'm missing something...
No the uk version the shaft has a metric thread which is slightly smaller than imperial thread on the US version. Also the uk shaft is not machined with the 2 flats which permit the thin spacer to be slid along the shaft
Jolly1
jolly1 is offline
post #22 of 35 (permalink) Old 06-18-2014, 02:24 PM
Country: Israel
First Name: Itamar
Oh, that makes it more complicated
from my measurement the arbor on my saw is 15.85 mm which is 0.02 from 5/8" do you think that would make a difference ?
ibonneau is offline
post #23 of 35 (permalink) Old 06-24-2014, 05:44 PM Thread Starter
Thread on the UK version is considerably finer than the US version, which is an ACME thread, I would guess the dado blade sitting on the thread would cause damage. Just a guess.
I have been using the dado blade on the US shaft with no problems.
Jolly1
jolly1 is offline
post #24 of 35 (permalink) Old 06-21-2015, 05:35 AM
Hi Jolly1,
I am new to this forum. But I have read with interest your posts on the dado blade. I also own the EU model of the GTS 10 XC Prof (Swiss/German model)
A couple of more questions:
1) Which Freud 8 inch Dados did you order (where?): I had those in my focus: amazon.com/Freud-SD208-8-Inch-Professional-Dado/dp/B0000223O9? (Sorry I am not allowed to post links)
2) Are there any other parts needed besides the listed items/parts in the beginning of the post - > I do not want to order twice in the US due to the high shipping costs.
3) Are there any other recommendations?
Thanks a ot.
Best regards,
Chris.
cpbee is offline
post #25 of 35 (permalink) Old 07-13-2015, 12:48 PM
Hi Guys
Regarding the throat plate...will the standard 4100 dado throat plate (TS1007) fit the UK Bosch GTS 10XC?
regards
jramurray
jramurray is offline
post #26 of 35 (permalink) Old 10-20-2015, 05:21 AM
Hi Jorge,
I have a question about extracting the armature from the motor of my GTS 10XC table saw. The fan fitted on the armature of mine is broken (how is it possible) ant I would like to fix it.
For now I've removed the motor housing, motor cap, carbon brush set, but I can't pull out the armature.
Can you tell me if it is possible to remove / put back in place the armature from this side, or do I have to completely dismantle the gear housing side of the motor?
Thanks in advance for your answer!
Colinus
colinus is offline
post #27 of 35 (permalink) Old 10-20-2015, 09:46 AM
Originally Posted by Jtrwoodworks View Post
I'm having a similar prob. With fitting a dado set. Is the 4100 arbor longer than the one fitted to the gts 10xc?
Also is it poss to use 30mm bore dado set?
John
yes...
the 4100 will take a full dado set...
post #28 of 35 (permalink) Old 10-20-2015, 09:48 AM
Originally Posted by Phil P View Post
Hi Guys and welcome John
Anyone like to tell me what the fascination with using a dado set is? Especially on a portable (site) saw?
Regards
Phil
expanding the versatility of what they have...
post #29 of 35 (permalink) Old 11-02-2015, 09:06 AM
First Name: David
Question
Originally Posted by jolly1 View Post
Currently I am modifying the mitre slide to remove the small amount of sideways play.
Hi, John,
Thanks for the details of the parts. I have ordered them.
How did you get on with removing the sideways play? My two disappointments with the GTS10 XC are the sideways play and the stiffness of the mitre slide, so any light that you can cast on these would be very much appreciated. Thanks.
David.
David Dickson is offline
post #30 of 35 (permalink) Old 01-25-2020, 02:04 PM
Country: Romania
First Name: Florin
Hello!
I am new to this forum and I am also interested in the changes made to the GTS 10XC in order to use the Dado set.
If anyone else has made the change by changing the shaft, he can give me some tips. The intervention is complicated, I am interested in not to change settings something with it. It is new, under warranty, bought 2 weeks ago.
Maybe a link to the shaft change stages would be of great help to me.
All the best !
flobv72 is offline
