Another hair-brained dust collection scheme - Router Forums
post #1 of 28 (permalink) Old 12-07-2012, 09:45 AM Thread Starter
First Name: Chris
Default Another hair-brained dust collection scheme
I's not like I'm specifically trying to cobble together a dust collection system because I'm a penny pincher (which I AM by the way).
The reality is that in my garage, I already have 3 shop vacs, two of which are 2 1/2", and one is 1 1/4" and a leaf blower that essentially has a 4" inlet. I got 2 of them at yard sales for a total of $10, and the leaf blower is for the yard. I use the shop vacs from time to time for sucking up water and cleaning cars out and stuff.
Now I have a relatively new interest in woodworking, and am trying to be creative about setting up a dust collection system that uses the vacuum sources I already own.
So here is my latest hair-brained scheme:
Suppose I hooked up 2 (or more) of the vacuums to a larger PVC pipe (4 or 6 inches), each with its native sized connector. In this setup, the pipe would be large to the stations and dropping down as necessary at the tool. I'm thinking that multiple vacs on a larger pipe would increase the CFM significantly, resulting in much better duct collection at the stations.
Hair brained, or does it have merit? I guess one positive is that if I eventually have the desire and funds for a dedicated DC system, the backbone would already be in place.
Again, I ALREADY have these vacs, and I am just trying to come up with a creative way to make the best use of them.
Please don't tell me to go out and buy a "proper" dust collection system, because that is not going to happen.
Chris Curl is offline
post #2 of 28 (permalink) Old 12-07-2012, 10:05 AM
GulfcoastGuy's Avatar
First Name: Patrick
Sure. Use a piece of larger dia. pipe a a plenum. The two (or three) shop vacs will draw the pressure down in the plenum and you'll get the combined airflow (with some losses) to a single working port you could use as the source for your shop wide system. We used a similar concept in the Water Valley Holley Automotive plant (Now Bendix) to supply the vacuum flow for the mass flow testers throughout the plant.
GCG
GulfcoastGuy is offline
post #3 of 28 (permalink) Old 12-07-2012, 10:28 AM
First Name: Duane
Only issue I see with that idea is noise. You will definitely need hearing protection.
Dmeadows is offline
post #4 of 28 (permalink) Old 12-07-2012, 10:47 AM Thread Starter
First Name: Chris
cool. i suppose i could make an enclosure that houses them with some insulation for sound deadening to help with the noise level.
post #5 of 28 (permalink) Old 12-07-2012, 11:14 AM
First Name: Duane
That should do it!
Dmeadows is offline
post #6 of 28 (permalink) Old 12-07-2012, 11:30 AM
Remember to allow for heat exchange/cooling for the vac motors, Chris; with two of them in a confined space there'll be substantial heat buildup. If you can salvage the heat, not a bad way to heat your shop!
DaninVan is online now
post #7 of 28 (permalink) Old 12-07-2012, 11:54 AM
First Name: Patrick
Just put a vent low in one corner and an exhaust fan (computer box type) high in the opposite corner both insulated for sound and you'd be good to go.
GCG
post #8 of 28 (permalink) Old 12-07-2012, 11:58 AM
First Name: Joe
Shop vacs are designed to move small volumes of air at high velocity at a high static pressure. Like those dopey vacuum cleaner infomercials where the guy picks up a bowling ball as the crowd Ohhhs and Ahhhs...Their impellers are far too small to be used in a "system". They work well connected to small tools, like a Fein or Festool vac connected to a sander or router. That's just the way it is. Connecting a 2-1/2" shop vac, or 2 or 3, to a 4"-6" pvc main, while producing a very large amount of noise, will result in far too low of a volume of air at the needed velocity to keep dust and wood chips suspended. That's just the physics of it. I wish the numbers worked for you, Chris, really, but I see you putting a lot of time and effort into this and not being happy with the result.
Good luck.
J. Leigh is offline
post #9 of 28 (permalink) Old 12-07-2012, 12:25 PM
First Name: Patrick
Avg CFM for a shop vac is around 150. Three would max out at 450 (volume is volume), less in real world conditions. Rockler's hang on the wall system is spec'd at 650 CFM (less real world) rated for 4" duct work. Chris, your idea would be a definite boost IMO and worthy of exploration. Some inexpensive PVC pipe and fittings from HD or Lowes would be all that would be need to prove it.
GCG
post #10 of 28 (permalink) Old 12-07-2012, 12:26 PM Thread Starter
First Name: Chris
i could use a little extra heat out there in the winter months.
joe, i understand your points, and you could very well be right. but i think it can't hurt to give it a try. after all, i have more time than money these days. if i keep the receipts and just press fit the PVC pieces together, i can return the whole mess if it doesn't work out.
Index of Dust Collection Solutions and Comments allthunbs Shop Safety 28 03-14-2014 01:40 AM
Dust Collection on Table Saw Router Table Extension Guitarman1 Table-mounted Routing 0 10-02-2011 02:32 PM
Oak Park Dust Collection kawisser Table-mounted Routing 3 08-18-2011 07:32 PM
Dust Collection Tricks Marco Tools and Woodworking 8 07-22-2011 09:44 AM
Dust Collection Question Tigerpaw Table-mounted Routing 17 04-16-2009 04:42 PM
