How to remove carpet tape adhesive - Router Forums
post #1 of 28 (permalink) Old 12-12-2012, 03:50 PM Thread Starter
First Name: Doug
Question How to remove carpet tape adhesive
I had to make a new table saw insert today for a dado set.
I used double-sided carpet tape to hold the cast insert to the new hardwood insert.
I used my new 1/2" x 1-1/4" CMT flush-trim router bit and it turned out almost perfect.
However, after prying the cast insert off the new insert the adhesive is stuck to the cast. I mean really stuck! (There is a side story about having to unscrew the set screws after finding out they interfered with the router.)
I tried mineral spirits and then lacquer thinner but neither worked.
How do you remove the adhesive? Any tricks of the trade?
Jambe is offline
post #2 of 28 (permalink) Old 12-12-2012, 04:03 PM
GulfcoastGuy's Avatar
First Name: Patrick
Goo-Gone.
Homax GG12 Goo Gone - 8 oz.: Household Essentials : Walmart.com
Don't know how the wood will react so test it first.
GCG
GulfcoastGuy is offline
post #3 of 28 (permalink) Old 12-12-2012, 04:51 PM
A wide blade Putty Knife works well
HYDE Putty Knife, Stiff, 2 In, Nylon - Putty/Joint Knives, Spatulas, Scrapers - 5LL95|02300 - Grainger Industrial Supply
post #4 of 28 (permalink) Old 12-12-2012, 06:08 PM
+1 on the putty knife. Sometimes denatured alcohol will help but it depends on the mfg. I've had some where it wipes right off with the alcohol and others it wont touch.
John Schaben
jschaben is offline
post #5 of 28 (permalink) Old 12-13-2012, 12:30 AM Thread Starter
First Name: Doug
Goo Gone was not available at my WalMart but they had Goof Off. Claimed to remove adhesive. It didn't. Soaked it for half an hour--didn't do anything more than water! Can't scrap it off.
I wonder if a mild acid would work--like muriatic acid? Would it harm the cast insert?
Jambe is offline
post #6 of 28 (permalink) Old 12-13-2012, 12:42 AM
paduke's Avatar
acetone might help It removes Rhino double stick carpet tape when I use it
paduke is offline
post #7 of 28 (permalink) Old 12-13-2012, 03:24 AM
japa62's Avatar
I'd use Double D Eucalyptus Oil
Under construction, always.
japa62 is offline
post #8 of 28 (permalink) Old 12-13-2012, 04:29 AM
First Name: Andy
I second Bill's suggestion. The way I usually go with solvents is try methylated spirits (denatured alcohol) first, if that doesn't shift it try white spirit/mineral spirits, and if that's no good then go to acetone.
Naphtha/coleman fuel/lighter fuel might be worth a try to.
AndyL is offline
post #9 of 28 (permalink) Old 12-13-2012, 05:37 AM
JCJCJC's Avatar
Country: Ireland
Warm it up to soften it, remove as much as you you can mechanically with scrapers, chisels, wire wool etc, and use solvent to get the rest, white spirit, methanol, WD40.
JCJCJC is offline
post #10 of 28 (permalink) Old 12-13-2012, 05:48 AM
I can't believe Goof Off didn't take it off. I've never had any adhesive that it didn't work on.
jsears is offline
3M Carpet Tape 345 source? RROW Tools and Woodworking 4 06-09-2011 01:01 PM
carpet tape? deacon76 General Routing 8 03-05-2010 12:03 PM
Best Way to Remove Shurtape (double sided tape) Residue rstermer General Routing 9 12-13-2009 09:45 AM
Outdoor Carpet Tape FD_Cox Guide Bushings and Templates 8 05-04-2009 10:01 AM
