Gluing loose abrasive - Router Forums
post #1 of 12 (permalink) Old 01-03-2013, 02:03 PM Thread Starter
rwl7532's Avatar
First Name: Ralph
Default Gluing loose abrasive
I have lots of loose abrasive from when I was sandblasting etching glass.
Some Carborundum, Aluminum Oxide and Garnet.
I am thinking of gluing some to some wooden doweling so I can sand various small parts like the band sawn reindeers (picture attached). The doweling would be chucked in a drill.
What glue should I use?
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
post #2 of 12 (permalink) Old 01-03-2013, 02:39 PM
Gaffboat's Avatar
First Name: Oliver
When I built a sailboat I used sand sprinkled onto a layer of epoxy as non-skid for the deck. It worked exceptionally well and I think you could do the same to make your sanding dowels.
Gaffboat is offline
post #3 of 12 (permalink) Old 01-03-2013, 06:41 PM
me5269's Avatar
First Name: Michael
Send a message via AIM to me5269
Ralph,
Many years ago, I remember my father using hide glue.
me5269 is offline
post #4 of 12 (permalink) Old 01-03-2013, 06:42 PM Thread Starter
rwl7532's Avatar
First Name: Ralph
Originally Posted by me5269 View Post
Ralph,
I even have some!
rwl7532 is offline
post #5 of 12 (permalink) Old 01-04-2013, 06:41 AM
JOAT's Avatar
First Name: Theo
Years ago as an experiment in finishes I glued sparkles, or whatever that stuff is called. Glitter I think. Anyway, it went on quite well, and if it had been an abrasive I don't see why it wouldn't have worked. I used Titebond II - which I use for almost all my woodworking needs, works great. Of course probably any other woodworking glue would probably work as well, but I just like the Titebond II. Stuff like that, I never ask, just think about it, and if seems workable go ahead and try it - and it usually works.
JOAT is offline
post #6 of 12 (permalink) Old 01-04-2013, 08:18 AM
CharleyL's Avatar
First Name: Charley
While hyde glue may seem like a good idea, remember that the sanding process produces friction and heat. Hyde glue softens with heat, so your sanding device will self destruct as soon as it heats up. Go with a more heat resistant type of glue, like epoxy. Titebond may work OK if you are careful not to create too much friction while sanding. Most sanding products will fail if they get hot enough.
Charley
Central North Carolina
CharleyL is online now
post #7 of 12 (permalink) Old 01-04-2013, 08:57 AM
First Name: Richard
Send a message via Skype™ to rwbaker
Personally, I would try a 3 lb cut shellac for the super fine grit and polyurethane for a little larger grit. Since you are hand sanding heat is not an issue and if you stick it in the drill press what's the worst that could happen? Epoxy would be good for 60 and 80 grit. Just dip the end and roll in the grit.
Good Luck
Baker
rwbaker is offline
post #8 of 12 (permalink) Old 01-04-2013, 09:52 AM Thread Starter
rwl7532's Avatar
First Name: Ralph
Great input. I hadn't thought of shellac.
I have all the glues mentioned so far.
I think I'll get the best result using Epoxy.
The grits I have are 80, 150 and I think 100. Not sure about the 100 as it was unmarked when I got it.
The unmarked is black and I think carborundum.
I can't remember how I happened upon it. All the rest I bought in bulk back in 1987 or so.
rwl7532 is offline
post #9 of 12 (permalink) Old 01-04-2013, 12:57 PM
Contributor of the Month
OPG3's Avatar
First Name: Otis
Ralph, this is interesting! Please keep us posted on this when you have compiled some data, I feel confident many others beyond me will be very interested in your results. I have someone who does my sand / glass bead blasting and he will be glad to bring me any abrasives I have need for. There is quite a variety of glues that we use and also we use a huge quantity of wooden dowels - which would mean 2 out of 3 ingredients are here when needed (with the abrasive easily here).
On a slightly different subject, if you ever have need to do "grain-raising" - sand blasting can sometimes do the job very nicely and make a new piece of wood look decades old.
Take care my friend, Otis Guillebeau from Auburn, Georgia.
OPG3
Tweak everything!
OPG3 is offline
post #10 of 12 (permalink) Old 01-04-2013, 04:37 PM Thread Starter
rwl7532's Avatar
First Name: Ralph
I intend to set up sandblasting (for glass) in my garage. I miss it. Haven't done any since 1990!! I don't do high pressure blasting (requiring a dedicated blast booth). I've found that low pressure blasting can be contained with merely a shop vac supplying the negative pressure. Well most of the grit anyway.
I would be able to do "grain-raising" as that doesn't take much pressure or time -- compared to a sandblasted wood sign of course.
rwl7532 is offline
Stain before gluing? bioprof Starting Off 2 04-23-2011 08:17 PM
Gluing Primer rweerstra The Finishing Touch 9 09-06-2010 12:40 PM
Loose brass guide Hamlin Table-mounted Routing 6 01-11-2009 01:51 PM
Loose dado RuggerJoe Tools and Woodworking 2 03-13-2008 06:31 PM
Keeping something square when gluing? ygdrasil54 Starting Off 5 10-30-2006 04:59 PM
