Countersink for Wood - Router Forums
post #1 of 16 (permalink) Old 01-11-2013, 05:43 PM Thread Starter
First Name: Gene
Default Countersink for Wood
I'm looking for countersink for wood that is sharp enough to work on just plain old #2 pine. I've bought a set of Hitachi 1/4" through 3/4", thats all I could find a the big box stores. They work good when put in a drill press and really lay down hard on the press. But when using a hand drill I just can't get the depth that I need. I've run the drill slow and fast and nothing works. It is for #12 flat head screw. I know if anyone can help it will be you pro's
Thanks a bunch
LiLRdWgn is offline
post #2 of 16 (permalink) Old 01-11-2013, 06:16 PM
I use the LeeValley/Veritas... no complaints...
here's a sample...
Drill Bit/Countersink/Counterbore Units & Sets - Lee Valley Tools
post #3 of 16 (permalink) Old 01-11-2013, 06:51 PM
First Name: Wayne
I use these and have no complaints with them.
Buy Tapered Bit Set 16 Piece at Woodcraft
I have tried the less expensive sets and was not happy at all.
Making saw dust in Turtle Creek, PA.
Wayne
WayneMahler is offline
post #4 of 16 (permalink) Old 01-11-2013, 07:55 PM
Honored Member
First Name: pat
To ace this out, the CS should be piloted like the big 82 degree x 1/2" 4 flute countersink here.
Far right.
It will track down the hole without chatter. Must be a couple dozen at WL fuller.
Quillman is offline
post #5 of 16 (permalink) Old 01-11-2013, 08:47 PM
IC31's Avatar
First Name: Dave W
Take a look here - countersinks to do whatever you need them for:
McMaster-Carr
I have a selection from there and use them for metals as well as wood. I also have a couple of seldom used drill point CS's - but they will grab in soft wood and you will end up way too deep - real quick!!
Dave W
Quando omni flunkus, moritati (When all else fails, play dead - R Green)
IC31 is offline
post #6 of 16 (permalink) Old 01-11-2013, 09:03 PM
Quik Change Drill Bit Countersink Set Details
MLCS Screw Slot Router Bits
post #7 of 16 (permalink) Old 01-11-2013, 09:49 PM
I also like Lee Valley's. If you are just looking for a countersink with no drill bit these work really well. HCS 82° Single-Flute Countersinks - Lee Valley Tools
post #8 of 16 (permalink) Old 01-12-2013, 04:05 AM
japa62's Avatar
Yes Lee Valley's. We go to the shed to escape the chatter so a 'chatter free' countersink is the way to go.
Under construction, always.
japa62 is offline
post #9 of 16 (permalink) Old 01-12-2013, 05:30 AM Thread Starter
First Name: Gene
Thanks Guys, Thats what I get for getting in a hurry. The big box stores I went to the largest tapered that they had was for a #10 screw. I guess I just need to slow up and order what I need.
Thanks Again,
LiLRdWgn is offline
post #10 of 16 (permalink) Old 01-12-2013, 06:32 PM
First Name: Kerry
My experience has been the cross hole sets do a better job unless you have a drill press in which case the previous suggestions all make sense.
Kerry
Anybody can become a woodworker, but only a Craftsmen can hide his mistakes!
-Walter Blodget
Larkan is offline
