delta uni-fence add on - Router Forums
post #1 of 11 (permalink) Old 01-22-2013, 04:17 PM Thread Starter
Default delta uni-fence add on
I use a Delta uni-fence table saw and want to add a sacrificial face to the fence in order to easily use my daddo set. Does anyone have a suggestion to accomplish this?
twak is offline
post #2 of 11 (permalink) Old 01-22-2013, 05:14 PM
Phil P's Avatar
First Name: Phil
Hi Tom
It might seem like sacriledge but have you though about drilling a couple of neat, countersunk holes through the aluminium sliding fence section from the rear to hold a sacrificial piece using countersunk screws? Alternatively, if you don't want to drill your sub-fence, as the aluminium fence is held on by a couple of bolts why not just slide off the metal plate and bolt on a wooden one to replace it. A 2-minute scout of the web found this example which seems to do exactly what you need
Regards
Phil
Phil P is offline
post #3 of 11 (permalink) Old 01-22-2013, 09:43 PM
I have a Unifence and I drilled it exactly like Phil suggested. It only takes about a minute to attach it. I drilled one near each end and another just in front of the blade.
post #4 of 11 (permalink) Old 01-22-2013, 11:57 PM
Send a message via Skype™ to NoChatter
Uni T Fence
Not really sacrificial but just thought I would share. I DO NOT OWN ONE YET SO I CANNOT COMMENT on how well it works. I just bought the rockler clamps and only one of the clamps worked because of the mounting bracket is in the way. The main problem with the uni fence is that the backside is concave which makes that mod piece in the above link cool.
Sorry for yelling earlier.
NoChatter is offline
post #5 of 11 (permalink) Old 01-23-2013, 06:59 AM
First Name: Art
Last week there was a link to The New Yankee Workshop and in the episode Norm was making a jig for a Unifence. Do a search and it may come up. It was "part one" of his jigs.
mgmine is offline
post #6 of 11 (permalink) Old 01-23-2013, 09:04 AM
Default Delta Uni-Fence Add-on
I just added one to my Uni-Fence and here is what I did. Cut a 2x4 or whatever piece of wood you prefer to the length you want for your sacrificial fence and the same height as your Uni-Fence. Use a pair of Universal Fence Clamps (Rockler 31373) and drill 2 holes in the top edge of your sacrificial fence. Set the sacrificial fence against the Uni-Fence and slip the posts of the clamps into the holes, thighten up and you are on your way. I had 2 clamps from reading lights that clamp to a desk that I was able to use instead of the Rockler clamps but the result is the same.
Luigi
michmags is offline
post #7 of 11 (permalink) Old 01-23-2013, 09:46 AM
First Name: Duane
Luigi
Really like those Rockler clamps, I use them all around the shop!
Dmeadows is offline
post #8 of 11 (permalink) Old 01-23-2013, 12:57 PM Thread Starter
Thank you, everyone. You have shown me it is not rocket science after all. Thanks again.
twak is offline
post #9 of 11 (permalink) Old 01-23-2013, 02:19 PM
MAFoElffen's Avatar
There might be... Scheming.
Info from an Uni-Fence owner please... On a Uni-Fence, what is the measurements of the t-slot from bottom corner of the fence to the center of the t-slot? Then the width of the t-slot?
MAFoElffen is offline
post #10 of 11 (permalink) Old 01-24-2013, 02:02 PM
MAFoElffen's Avatar
Heres a painless store-bought solution from Peachtree Woodworking:
Uni T Fence - Delta Uni Fence Up Grade
Charles-
We talked around these lines. They already have the dies made and are producing... Not "too" bad of pricing. Then you could replace the face with whatever you wanted.
What else I was thinking about was a DIY solution, but I need Uni-fence measurements to come with something (project plans, etc). Picture attached: a. Need measurement from bottom corner of fence (A in attached photo) to center of mounting slot. b. Need diameter of mounting stud (B has 2 studs mounted to a t-plate that go through the L-head) or the dimensions of the mounting t-slot in the fence (A).
Name:	Screenshot from 2013-01-24 12:14:45.png
Last edited by MAFoElffen; 01-24-2013 at 02:22 PM. Reason: Added attached picture...
Some Thoughts on Fence Control Gilbear Table-mounted Routing 21 04-16-2010 05:38 PM
A Poor Man's adjustable Positioning Fence Stefang Table-mounted Routing 8 02-26-2010 03:22 AM
Sold: Delta T-2 Fence and Rail package $125 flyguy1 Woodworking Classifieds 2 08-27-2009 12:42 AM
Wanted: WTB..Table Saw Fence...Delta T-2 or Other deck99 Woodworking Classifieds 3 08-25-2007 10:21 PM
