bandsaw blade flex - Router Forums
post #1 of 28 (permalink) Old 01-27-2013, 10:02 AM Thread Starter
First Name: Paul
Default bandsaw blade flex
Is it safe for the blade to occasionally touch the guides when the blade flexes when you saw a curve? I'm using a delta 28-276 with the original guides. I have the distance set with a double thickness of a dollar bill.
thanks,
Paul
CAUTION: Blind Driver!
p3auul is offline
post #2 of 28 (permalink) Old 01-27-2013, 10:10 AM
Paul, when cutting curves the blade has to hit the guides, that is their purpose. Instead of the two dollar bills as shims watch the Carter bandsaw set up video by Alex Snodgrass on adjusting your saw. It is a sticky thread at the top of this section.
post #3 of 28 (permalink) Old 01-27-2013, 10:11 AM
First Name: Don
Paul,
Take a look at the sticky post above in this section, on band saw set up.
That was a great help for me----and I have an extra dollar in my pocket.
Don
Sawdust Don is offline
post #4 of 28 (permalink) Old 01-27-2013, 10:16 AM
Gene Howe's Avatar
First Name: Gene
Paul, in addition to Mike's good suggestion, you'll want to check out these COOLBLOCKS They can be adjusted right up against the blade and provide more stability on turns.
thanks,
Paul
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #5 of 28 (permalink) Old 01-27-2013, 01:49 PM
MAFoElffen's Avatar
I'm surprised no-one has mentioned the Carter Bandsaw Stabilizer type of guides... Made just for using 1/4" wide and less bandsaw blades for cutting tight curves...
Just a thought.
MAFoElffen is offline
post #6 of 28 (permalink) Old 01-27-2013, 05:12 PM
First Name: Don
I will say the carter stabilizer works well.
My used saw came with one, I did not know what it was for until I saw the video.
It allows the blade to flex for tighter turns for a given blade width.
post #7 of 28 (permalink) Old 01-27-2013, 05:32 PM
It's on my wish list Mike.
post #8 of 28 (permalink) Old 01-27-2013, 06:47 PM
Does anyone know if the stabilizer will work on a 12" band saw?
Sydney, Australia
jw2170 is offline
post #9 of 28 (permalink) Old 01-27-2013, 08:02 PM
First Name: Duane
Each stabilizer is made for a specific model bandsaw. There website will tell you if one is available for yours, James.
Dmeadows is offline
post #10 of 28 (permalink) Old 01-27-2013, 08:03 PM
curiousgeorge's Avatar
First Name: George
James, I see no reason why it wouldn't if they make one for the brand name of the bandsaw you use. You would have to check the Carter web site to see.
I am using the stabilizer right now on my Shopsmith 14" with a 1/4" blade. It's amazing how small a radius you can turn with it. There is a slight learning curve tho and it has to be set up properly.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
Bandsaw Blade Tensioning? rpludwig Tools and Woodworking 13 04-08-2013 07:18 PM
Bandsaw blade substitution chessnut2 Tools and Woodworking 11 12-18-2012 04:39 PM
Bandsaw blade for oak? Chris Curl Tools and Woodworking 4 04-15-2012 12:47 AM
best bandsaw blade for hardwood screwy1 Tools and Woodworking 5 06-03-2011 03:12 AM
Bandsaw blade problem seawolf21 Tools and Woodworking 4 05-01-2009 10:41 PM
