Joining with a 7.5 degree angle - Router Forums
post #1 of 17 (permalink) Old 02-08-2013, 01:28 PM Thread Starter
First Name: Kevin
Default Joining with a 7.5 degree angle
I have some trouble with joining. I am constructing a circle using 24 panels of cedar. They are 15" long. I must get a 7.5 degree angle on the long sides so I can join them all together to form a 30" circle. Picture the panels all standing up to form the circle. Does anyone have some advice so I may get a good join? Sure would appreciate anything you folks might have that would help. Drums are very important to indian people so I strive to make them as though they are fine furniture. Here are some pics.
Turtlemakesdrums is offline
post #2 of 17 (permalink) Old 02-08-2013, 01:47 PM
multi glue joint
MLCS Euro door, door lip, finger pull, drawer lock bits, glue joint router bits
post #3 of 17 (permalink) Old 02-08-2013, 02:27 PM
rwl7532's Avatar
First Name: Ralph
You are making a stave drum.
My advice would be to practice your angles using cheaper wood and making a smaller (e.g. 14" diameter) drum.
A Wixey digital angle gauge must be 'dialed' in. That is, since it doesn't show all the decimal places, you should swing your blade back and forth to determine the true 'middle' point that is the true angle of 7.5
Getting the angle right is step one.
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
post #4 of 17 (permalink) Old 02-09-2013, 07:15 AM
First Name: Art
As Ralph suggested get a Wixey digital angle gauge. They seem to get repetitive results better than others. Also I would use a Incra miter gauge on a table saw. If you make these more than once (which looks like you do) then the investment will be worth it.
mgmine is offline
post #5 of 17 (permalink) Old 02-09-2013, 03:28 PM Thread Starter
First Name: Kevin
Thanks for the advice. I do have a digital angle guage or I would not be able to do this very well. I was thinking that I should probobly take a smaller final cut instead of just one cut. The real tricky part is putting it all together before the glue begins to set up. That pic looks a lot like my big drums except I bullnose the ends before assembly.
post #6 of 17 (permalink) Old 02-09-2013, 03:36 PM
rwl7532's Avatar
First Name: Ralph
Routing the bearing edge after glue up and after rounding the outside and inside is how I have done it. Special jig required for a drum of your size.
rwl7532 is offline
post #7 of 17 (permalink) Old 02-09-2013, 04:49 PM
rwl7532's Avatar
First Name: Ralph
Also, make certain your table saws insert is level with the table on all sides.
rwl7532 is offline
post #8 of 17 (permalink) Old 02-09-2013, 09:43 PM
Default do it in 2 halves
This works with any polygon with an even number of sides - geometry rules - 24 sides = 360 degrees so 12 sides must be 180 degrees and 180 degrees is what you get when you do the sanding I have described below.
I did it like this for an 8 sided thing.
After you have done all of your testing to get the 7.5 degrees right.
Glue up 2 lots of 12 panels to form two "semi cylinders" a bit like the letter "n"
Do a dry run to see if the two semi cylinders meet perfectly.
If they do not then they will probably be close - glue some fine sandpaper to a perfectly flat surface and run the semi cylinders on the sandpaper so that the bottom of the two stalks of the "n" get abraded
When you have rubbed it so that the first and last edges of both "n"'s are sitting perfectly flat on the sandpaper then they should meet and glue together quite well.
Worked for me with an 8 sided thingummy.
Bill
steamingbill is offline
post #9 of 17 (permalink) Old 02-09-2013, 10:33 PM
woodworkingmenace's Avatar
First Name: Jesse
If I were going to do a lot of those drums, I would have made a smaller version of it, put wax paper around it and stapled it, then, got the angles, and put some slow setting glue around the edges and put it on the outside of the smaller one, and band clamped them.
But, silly me, I always did do things the hard way LOL
I wish you well...
Jesse
woodworkingmenace is offline
post #10 of 17 (permalink) Old 02-09-2013, 10:38 PM
First Name: Jesse
Just a thought, couldnt you have made wedges and put some two sided tapes on the planter, both before and after the blade and then ran the boards over the blades to get your 7.5 degree angle? (This is taking into the account that the wedges and tape 'make' the 7.5 degree angle already, and its close enough so that you run along the fence).
Just a thought.
I wish you well...
Jesse
Dovetail bit question 8 degree versus 14 degree. Timmberman Router Bits - Types and Usage 9 07-04-2018 10:27 AM
Does this exist? 60 degree reversed chamfer bit Spitfire7 Router Bits - Types and Usage 41 03-10-2018 07:51 AM
Achieving 30 degree angle pinyoro Router Bits - Types and Usage 4 06-24-2011 08:12 PM
Dovetail on a Picture frame ( 45 Degree Angle ) woodaholic General Routing 8 07-26-2009 02:03 PM
Perfect 22.5 degree miter Kristin D Tools and Woodworking 11 02-26-2008 05:59 PM
