What's wrong with this band saw? - Router Forums
post #1 of 25 (permalink) Old 02-09-2013, 08:47 AM Thread Starter
First Name: Bryan
Default What's wrong with this band saw?
I recently purchased a used Inca 342.186 band saw. It's probably 20 years old. Both the thrust bearings were seized, so I purchased new ones. I noticed that the upper bearing had been badly scored near its hub by the back of the blade and assumed the previous owner hadn't known how to properly adjust the upper guide. Now, though, I can see what the problem was
The first two photos below show the guides with the table and top wheel removed. The third shows a close-up of the upper guide with the top wheel back on and a 1/2-inch resaw blade mounted. The back of the blade is clearly contacting the thrust bearing at nearly the center, rather than along the outer rim as it should - just as it did for the previous owner.
I can't see any way of adjusting the thrust bearing fore and aft within the guide housing. Nor will the guide housing adjust fore and aft - just up and down as you would expect.
Has anyone any thoughts on how to deal with this? Thanks in advance
Atlantic Bryan is offline
post #2 of 25 (permalink) Old 02-09-2013, 10:05 AM
First Name: richard
Are the gullets of the blade centered on the wheel? Weird they don't give an adjustment for different sized blades. Can you get a manual for the saw?
richtink is offline
post #3 of 25 (permalink) Old 02-09-2013, 11:57 AM Thread Starter
First Name: Bryan
The problem is not for various sizes of blade, Richard. The guides and the bearings slide in and out as they should. It's the position of the blade left and right (in the photos). The blade should be almost 1/4 inch to the right in the close-up so that it rides on the outside edge of the bearing.
I can't find a manual. Robin Lee of Lee Valley Tools (LVT used to handle Inca) posted manuals for a number of Inca tools in another forum, but only a parts manual for the band saw.
post #4 of 25 (permalink) Old 02-09-2013, 01:53 PM
rwl7532's Avatar
First Name: Ralph
From the photo, it looks like the tires are thicker than expected. Maybe replacement of the tires will bring the blade further from the center of the thrust bearing.
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
post #5 of 25 (permalink) Old 02-09-2013, 02:10 PM
First Name: richard
Very observant. That would surely solve the problem.
richtink is offline
post #6 of 25 (permalink) Old 02-09-2013, 02:23 PM Thread Starter
First Name: Bryan
That might help. The tires are about 1/8 inch thick. How thin are replacements - anyone know off-hand?
post #7 of 25 (permalink) Old 02-09-2013, 02:28 PM
rwl7532's Avatar
First Name: Ralph
My 14" jet's tires are about 1/16".
rwl7532 is offline
post #8 of 25 (permalink) Old 02-09-2013, 04:40 PM
First Name: Duane
Uh, thinner tires would move the blade closer to the center of the bearing! Many bandsaws I have seen are set up that way. Don't know that there is an easy solution other than maybe a set of Carter bandsaw guides. Depending on what you gave for the saw the Carter guides may well exceed that price. May also be a ceramic guide available...that would reduce wear.
My Grizzly is setup the same way.. have changed bearings once in 18 years. YMMV.
Dmeadows is offline
post #9 of 25 (permalink) Old 02-09-2013, 04:46 PM
rwl7532's Avatar
First Name: Ralph
Closer to the center of the bottom bearing, yes. The pics concentrated on the top bearing.
rwl7532 is offline
post #10 of 25 (permalink) Old 02-09-2013, 04:48 PM
First Name: Duane
Ralph, I don't care which set it is, if you reduce the diameter of the wheel, the natural tracking line will move toward the middle.. not the outside!
Dmeadows is offline
What Did I Do Wrong dustywoodworker Table-mounted Routing 16 02-22-2012 09:12 AM
tear out - what went wrong ? jkristia General Routing 12 06-16-2010 07:05 PM
Did they send the wrong plate? MinorHero Table-mounted Routing 3 12-13-2009 09:36 AM
Making a template, where did I go wrong? Thom2 Guide Bushings and Templates 10 08-09-2007 07:54 AM
Things wrong with site 46_trap Lobby 14 07-25-2005 12:36 PM
