More Questions About GO432 Lathe - Router Forums
post #1 of 4 (permalink) Old 02-16-2013, 02:19 PM Thread Starter
First Name: Jerry
Default More Questions About GO432 Lathe
I'm now looking at the Grizzly GO462 lathe and see that the lowest speed is listed at 600 RPMs, but a post on another thread implies that this speed is to fast for turning large diameter bowls which is one of the things that I want lathe for. My question has to do with the importance of the speed of the lathe for such bowls and what is the ideal speed for that appliation. Also, any comments on this peticular machine will be very much apprciagted. So far, I am very happy with my Grizzly jointer and band saw and would like to stay with their products.
Jerry Bowen
Colorado City, Texas
The place where the largest oil find in the history of the country is taking place place, we are excited about the potentual of this find. Actually the find is all of Mitchell County and is just beginning in this part of Texas.
Jerry Bowen is offline
post #2 of 4 (permalink) Old 02-16-2013, 03:13 PM
First Name: Duane
I assume you are asking about the G0462? The speed range is some what typical for that class of lathe. here is another example..
http://www.rockler.com/product.cfm?p...FYxDMgod-g0A6g
It's low speed is 550RPM. 550 or 600 is probably slow enough for any thing I would want to turn on that size lathe. How large of bowls are you wanting to turn, Jerry?
The G0632 will go down to 100RPM, but it is nearly 3 times the price. It should be more suitable for larger projects.
Dmeadows is offline
post #3 of 4 (permalink) Old 02-16-2013, 03:39 PM
First Name: Duane
One turners recommendations...
The rpm will vary, but a general rule for getting a concept are these published recommendations from Dale Nish:
(Diameter, roughing rpm, finishing rpm)
5" 1200 to 1800
6" 1000 to 1500
7" 850 to 1250
8" 750 to 1125
9" 650 to 1000
10" 600 to 900
12" 500 to 720
600 RPM is not out of line for 12" bowls, Jerry. Also depends on the depth.
Dmeadows is offline
post #4 of 4 (permalink) Old 02-16-2013, 05:35 PM Thread Starter
First Name: Jerry
Default Thanks Duane
5" 1200 to 1800
6" 1000 to 1500
7" 850 to 1250
8" 750 to 1125
9" 650 to 1000
10" 600 to 900
12" 500 to 720
Duane, thanks for your response to my inqiry. Yes, I was referring to the model that you made reference to, my error. I have never turned anything on a lathe, but did out some rings together for my brother to use to turn some bowls that are about six inches in diameter. I am thinking that would like to make salad bowls, one large one and several serving ones. I'd like for the large one to be at least 12"s and would like for it to be evern larger. I'm limited to what I can justify to spend on a lathe. I'd like to stay under a thousand dollars and there are several in that price range to choose from. Since I have two Grizzly machines now, I'd kinda like to stay with that line of machines if I can and right now the GO462 looks like a good bet. But since I'm not ready to buy right at the moment, I'm doing my research on what to buy and the help that you have provided is exactly what I had hoped that I would get, thanks again.
Jerry
Questions about mounting a lathe and motor. AlmostHandy Woodturning and Lathes 10 09-29-2011 11:20 PM
Which bit? Duplicating lathe with mounted router msn56 General Routing 5 03-04-2011 02:26 AM
Got the lathe, now all the questions! CanuckGal Woodturning and Lathes 19 12-21-2009 10:53 AM
Oneway Lathe jd99 Woodturning and Lathes 13 12-16-2009 08:19 AM
Router Lathe bobj3 The Bargain Bin 9 06-24-2009 03:12 AM
