Chisel honing guide build - Router Forums
post #1 of 13 (permalink) Old 02-17-2013, 07:45 PM Thread Starter
First Name: Chris
Default Chisel honing guide build
I glued two paint stirrers together to make a 1 1/2 by 1/2.
After it was, I cut off a 3 1/2" long piece for the base.
Then I used a 1/4" router bit and made a 5/16" groove all the way across, and two shorter 1/4" grooves.
Then I ground down two carriage bolts so they were 1/4" wide.
Then I made the wheel assembly using a 5/16" bolt, a couple of 1/4" washers and 2 skate board bearings.
Then I drilled 1/4" holes in the base and put the carriage bolts and wheel assembly together.
Chris Curl is offline
post #2 of 13 (permalink) Old 02-17-2013, 08:01 PM Thread Starter
First Name: Chris
Then it was time to work on the clamping mechanism, I glued a small piece to the base dead square as a reference for the blade.
Then I took another 3 1/2" piece of the stock and used the base to drill matching holes in the top. I made these a tad larger so there would be some play to make them slide up and down more easily and conform to the angle of the chisel.
I glued another piece paint stirrer to the top after cutting it short enough to allow clearance for the reference blok put on the base.
To keep the axel from falling out, I put a little screw with a washer in the base to hold it in.
post #3 of 13 (permalink) Old 02-17-2013, 08:08 PM
BRAVOGOLFTANGO's Avatar
First Name: Bravo
Awesome Chris, I'm just now starting mine lol, my Son came up for the weekend. You do good work sir.
BRAVOGOLFTANGO is offline
post #4 of 13 (permalink) Old 02-17-2013, 11:44 PM Thread Starter
First Name: Chris
Thanks!
I think this is FIRST time I have ever actually designed the entire thing using SketchUp, and then built it exactly as I designed it.
Usually I sketchup about 1/2 of it and then I hit a problem I hadn't thought about during the build.
PS - my son is at college, and even when he does come, he either stays up all hours and sleeps till 3pm
post #5 of 13 (permalink) Old 02-18-2013, 12:26 AM
First Name: Bravo
Originally Posted by Chris Curl View Post
Thanks!
I've tried my darndest to come back and do as-built drawing modifications once a project is complete. But I will say so far at least except for my Son's rocking chair, I have not had to change, rather built exactly as Sketchup was done. That's a good feeling to build to spec and it work.
I just now, literally am printing the drawings and maybe start in the morning (off tomorrow).
post #6 of 13 (permalink) Old 02-18-2013, 12:30 AM Thread Starter
First Name: Chris
Bret, do you use sketchup, and if so, how do you print it?
post #7 of 13 (permalink) Old 02-18-2013, 01:46 AM
First Name: Bravo
Absolutely, been using it for about 3 months now, not as proficient as I'd like to be yet, but getting there.
I print to our inkjet wirelessly, or my work printer sometimes, so it's fully compatible with most printers (that I know of at least).
Sometimes I'll get a wierd micro print waste of page though, so I started using PowerPoint and it's spot on whatever angle I choose without any nonsense, nice thing about Ppoint is you automatically get a landscape print which is what I primarily use. I literally print-screen (same thing as Ctrl-C) from Sketchy, Alt-Tab (fast switch) to Ppoint and Ctrl-V (paste) while on the Ppoint software, it auto centers and if you choose you can grab a couple corners to fit the page completely (seldom need to).
post #8 of 13 (permalink) Old 02-18-2013, 07:18 AM
First Name: Doug
Send a message via Skype™ to vzbingo
Just thought I'd let you know you can set up your SketchUp output by clicking on the printer properties tab when you select Print. If you download Cute PDF from CutePDF - The free PDF Converter, Convert to PDF for free, Free PDF Utilities. you can print directly to pdf. It's a freebie.
Name:	Sketchup Print.png
Creator of high grade sawdust and artistic glue spots
"Opportunity is missed by most people because it is dressed in overalls and looks like work." T. Edison
vzbingo is offline
post #9 of 13 (permalink) Old 02-18-2013, 07:25 AM
First Name: Doug
Cool
BTW, Neat sharpener build. I think I'll do one myself!
vzbingo is offline
post #10 of 13 (permalink) Old 02-18-2013, 08:21 AM Thread Starter
First Name: Chris
Bravo, thanks. I was curious if you did something to print it in the actual dimensions or just as a reference. I usually just run back and forth. There is a way to print it 1:1 size, but it is a pain to get it right.
Bingo, thanks. That PDF maker looks like it would be useful.
Craftsman-Bosch router guide WillMatney Jigs and Fixtures 21 07-26-2015 05:56 PM
Inlay work with template guides : a guide matt1710 Guide Bushings and Templates 11 01-22-2012 04:36 PM
Freud Edge Guide Mystery Chappmann Jigs and Fixtures 4 12-26-2011 01:36 PM
Ryobi Straight Edge Guide doesn't fit Ryobi RE180PL1 Router BabyGerald General Routing 1 09-16-2011 07:31 PM
spent some time sharpening... reikimaster Tools and Woodworking 7 10-01-2007 09:03 AM
