New fangled workbench build G Roofner - Router Forums
 1Likes
post #1 of 63 (permalink) Old 03-04-2013, 07:07 PM Thread Starter
roofner's Avatar
First Name: Gary
Default New fangled workbench build G Roofner
One leg finished here is picture.
http://www.routerforums.com/attachme...1&d=1362445591
roofner is offline
post #2 of 63 (permalink) Old 03-04-2013, 08:16 PM
First Name: Chris
i am definately following this! it is not too late to change my mind and do the legs like that.
what screws does it call for? how deep are the countersinks? how wide is the wider piece?
Chris Curl is offline
post #3 of 63 (permalink) Old 03-04-2013, 09:02 PM Thread Starter
roofner's Avatar
First Name: Gary
They are 3/8 and 6 inch long. I screwed up should have drilled 1/4 pilot holes. Very hard to
drive 3/8 screws without pilot holes. Going to put 3/8 dowels into drill pilot holes.
roofner is offline
post #4 of 63 (permalink) Old 03-04-2013, 09:16 PM
First Name: Chris
is that wider piece a 2x8 or 2x10?
post #5 of 63 (permalink) Old 03-04-2013, 09:47 PM Thread Starter
roofner's Avatar
First Name: Gary
Its a 2x8 larger but new standard 2x8 is 7.25 . Ripped a 2x10 removed both beveled edges and ripped 7.5 per print.
roofner is offline
post #6 of 63 (permalink) Old 03-05-2013, 02:44 PM
First Name: DAVID
Good Job Gary
IRONMULE31014 is offline
post #7 of 63 (permalink) Old 03-15-2013, 11:39 PM
First Name: Chris
Gary, how are the ends that hold the long pipes in place attached to the well walls? I am imagining a few options, but I'm not really happy with any of them. Now I'm starting to think that just a 3" lag bolt would probably be adequate.
How are you going to attach them?
post #8 of 63 (permalink) Old 03-15-2013, 11:53 PM Thread Starter
roofner's Avatar
First Name: Gary
Plans don't show an anchor?
roofner is offline
post #9 of 63 (permalink) Old 03-16-2013, 12:04 AM
First Name: Chris
i don't have the plans ... i'm winging it.
Are you saying that the plans you got don't show them attached?
post #10 of 63 (permalink) Old 03-16-2013, 06:35 PM Thread Starter
roofner's Avatar
First Name: Gary
No connection in the plans other than to the floating jaw is attached with screws.
roofner is offline
Build a prototype first Mike Starting Off 12 03-03-2015 05:54 PM
New fangled bench build Chris Curl Tools and Woodworking 54 05-01-2013 08:50 AM
New fangled workbench roofner Tools and Woodworking 58 03-11-2013 06:10 AM
my new workbench build trojan62 Show N' Tell 13 10-24-2012 03:14 PM
Workbench - router table : connection dilemma. matt1710 Table-mounted Routing 22 12-26-2010 02:54 PM
