Clamp For Compount Mitered Frame? - Router Forums
 1Likes
post #1 of 13 (permalink) Old 03-05-2013, 01:23 PM Thread Starter
First Name: Jerry
Default Clamp For Compount Mitered Frame?
Just wondering if anybody has successfully designed or found a clamping system and/or device that works well for clamping together a picture frame that consists of compound mitered work pieces????
Jerry Bowen
Jerry Bowen is offline
post #2 of 13 (permalink) Old 03-05-2013, 09:11 PM Thread Starter
First Name: Jerry
Just attempting to get this thread back up into the New Post area and hoping for some help or ideas on the subject.
Jerry
post #3 of 13 (permalink) Old 03-05-2013, 10:09 PM
This item from Lee Valley might do it. Spring Clamps & Pliers - Lee Valley Tools
If that doesn't work think about using a good sticky masking tape. Many joints can be held together with it. Maybe adding biscuits or splines at the corners would help stabilize it.
I don't know if it will be possible to put much pressure on the corners but if they fit really well together you probably don't need much. One last option I have is to take a piece of ply/mdf/osb/ or particle board that is bigger than your frame and fix 2 boards at 90 degrees to each other and then 2 adjustable boards and gently squeeze it all together. If you tape the bottom of the joints together and squeeze the tops just enough to keep the joints together it should work.
post #4 of 13 (permalink) Old 03-05-2013, 10:30 PM
Merle Multi-Corner Clamp Details
MLCS picture frame and cornice router bits
Jerry Bowen
Name:	freame clamp.jpg
post #5 of 13 (permalink) Old 03-11-2013, 07:38 AM
dutchman 46's Avatar
First Name: Howard
I like a method I seen on the Tommy Mac Donald show, "Rough Cut" PBS. He makes blocks that He glues on the outer edges of each board. Then by taking clamps and tightening them on the corners draws them together nicely, and You can see each glue joint perfectly. The blocks have 3 sides One 90 degree and one 45 degree edge. Putting a clamp on the two glue box 45 degree edge gives You the terfect gluing line. Use a softer wood, and any bits and pieaces that remain on Your frame after chiseling off the glue block, can be easily planed off!
jrod48 likes this.
John 3:16
dutchman 46 is offline
post #6 of 13 (permalink) Old 02-12-2014, 07:53 PM
rwl7532's Avatar
First Name: Ralph
Default Merle clamp
Anyone use the Merle clamp?
Success? Fail? Something in between?
I'm about to pull the trigger at MLCS....
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
post #7 of 13 (permalink) Old 02-12-2014, 11:09 PM
Semipro's Avatar
First Name: John_*
These work well
Collins Tool Co. - Tighter Joints. Quicker Production.
Semipro is online now
post #8 of 13 (permalink) Old 02-13-2014, 09:35 AM
berry's Avatar
First Name: Berry
Here's what I used for picture frames, although I don't make compound miters.
Those little corner pieces help with the glue up. These 'glue blocks' are just triangle scrap glued to a little piece of hardwood with sandpaper attached to the bottom. They are clamped to the picture frame with the Quick Clamps. Then I use the Bessey to draw the two corners together. Once again sandpaper insures they don't slip in the process.
You get excellent clamping pressure and I only work on two corners at a time so I really nice fit. Hope this helps.
May the grain be ever in your favor.
berry is offline
post #9 of 13 (permalink) Old 02-13-2014, 02:19 PM
TwoSkies57's Avatar
Hey Ralph..
I have two clamps similar to the Merle. Both have nylon bands rather than steel. One is a Craftsman and the other, I think is a Bessey. I'd have to check. For frame work, I love em both... work great, provide plenty of pressure. Not sure of what you plan to use em for,, but I"d have no problem rec. them.
Bill
Skipper the Penguin
TwoSkies57 is offline
post #10 of 13 (permalink) Old 02-13-2014, 03:38 PM
rwl7532's Avatar
First Name: Ralph
Originally Posted by TwoSkies57 View Post
Hey Ralph..
Bill
Thanks,
I'm thinking picture frames to start with. I bought the Incra V120 miter gauge and my first frame turned out spot on but I wasn't happy with the clamping method I'm using.
I'll have to post a picture of that method. I'll add to my post when I get the pics.
rwl7532 is offline
Mitered Door Frame bit on maple kopasetic Router Bits - Types and Usage 5 08-07-2012 07:49 PM
How to Make a Mirror Frame learnexperience General Routing 7 11-03-2011 07:34 PM
Edge routing mitered frame. RJK General Routing 9 09-12-2011 07:48 PM
How to Make a Decorative Picture Frame Using a Router learnexperience Tools and Woodworking 1 08-02-2011 11:47 PM
Mitered raised panel doors bobj3 Table-mounted Routing 13 09-03-2010 12:37 PM
