parkinson vice rebuild - Router Forums
post #1 of 3 (permalink) Old 03-09-2013, 09:16 AM Thread Starter
carl.p's Avatar
Country: South Africa
First Name: carl
Default parkinson vice rebuild
hi all can any one shed some light on this make of wood workers vice i bought from a school that closed down its wood work classes, its a parkinson patent perfect vice regards carl. ps have some idea it might be british made possibly about 60 to70 years old
carl.p is offline
post #2 of 3 (permalink) Old 03-09-2013, 10:10 AM
Phil P's Avatar
First Name: Phil
Hi Carl
Yes, it's British, and it's probably pre-WWII. Parkinson's were one of the "big names" in cast metal vices between the wars (others being Woden, Rededa, Marples and Record). During WWII they all appeasr to have stopped making vices to concentrate on war production. Because of the continuing need the MoS (Ministry of Supply) awarded the contract for a sole vice maker to a firm of cast-iron grate makers called Fred Parry in Rotherham (later called Paramore) - but using Record's casting patterns! I know that Record (C & J Hampton), Woden and Marples started up again after the war (both Woden and Marples were later to be taken over by Record), whilst Paramore continued making near copies of the Record products, but my understanding is that Rededa and Parkinson didn't recommence.
Parkinson's were one of the first firms in the UK to produce a quick release vice (from what I've seen before WWI) and to date I've only seen two styles of vice, earlier and later models. I've stripped and refurbed both in the past. Any chance of a photo so I can identify yours? Main things to watch for are cracks in the jaws (bad news), soft spring (the use a flat coiled spring a bit like those in a clock) and missing/damaged split nut
Regards
Phil
Phil P is offline
post #3 of 3 (permalink) Old 03-09-2013, 10:23 AM Thread Starter
carl.p's Avatar
First Name: carl
Originally Posted by Phil P View Post
Hi Carl
Regards
Phil
hi Phil no this vice is in mint condition i am just giving it a clean up and repaint no cracks or missing parts.regardscarl will try and post apic for You.
carl.p is offline
Vice for Xmas/Anniversary options? Chris Curl Tools and Woodworking 25 12-31-2012 07:58 PM
Other (Not Listed) Zyliss/Z-vice/Profi-King vice allthunbs Other & Specialty Manuals 3 08-19-2012 10:09 AM
Zyliss 4x1=1 Vice Jeffers New Member Introductions 9 08-06-2012 08:48 AM
Attaching a vice to a bench rail?? matt1710 Tools and Woodworking 10 09-24-2010 09:20 AM
Need vice ideas for new bench Birch Tools and Woodworking 9 04-15-2009 08:52 AM
