miter saw problem - Router Forums
post #1 of 5 (permalink) Old 03-12-2013, 09:10 AM Thread Starter
First Name: Joel
Default miter saw problem
Hi. I have a porter cable compound miter saw, is not used for chopping 2×4 on a job site. I have shop in my garage where I dd small projects . My problem is that the saw will not cut a true 90,. When I cut a wider board (7” to 8”}it leaves a notiiceable hump iin the middle {put it on the table saw and it rocks}. The fence is square to the blade. I replaced oem blade withe a Freud thin kerf blade. still have the problem.
Any body have any suggestions.
Thanks Joel
stripper is offline
post #2 of 5 (permalink) Old 03-12-2013, 09:32 AM
cagenuts's Avatar
Country: South Africa
First Name: Hilton
Send a message via Skype™ to cagenuts
Not exactly sure what you mean by a 'hump' but is your blade square to the table as well as the fence?
cagenuts is offline
post #3 of 5 (permalink) Old 03-12-2013, 11:09 AM
MikeMa's Avatar
Sounds like you are getting runout on the blade. This is either caused by bad bearings, or a bent arbor. If the saw is still under warranty, I would get it replaced.
If not, I don't know how serviceable the saw, but if the arbor is bent, I would consider retiring that saw and replacing it with a newer saw.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #4 of 5 (permalink) Old 03-12-2013, 05:44 PM
Joel are you using a cheap square to check 90 with? Not all squares are that accurate. One way to check is to take a sheet of something with a really straight edge like mdf or particle board and make a 90 on it, then flip the square over and see if it follows the line. The detents on some saws are also not very accurate, at least not from the factory.
post #5 of 5 (permalink) Old 03-12-2013, 08:53 PM
paduke's Avatar
Mike nailed it. If its not under warranty it should be easy to break the case and remove the bearings. Go to a bearing supply shop with them and buy two new ones. If its not the bearings its probably the arbor
paduke is offline
Kreg Miter Gauge vs. Incra Miter Gauge Jerry Bowen Tools and Woodworking 8 06-04-2012 08:58 AM
The Problem With The Incra Miter Gauge Jerry Bowen Tools and Woodworking 16 05-31-2012 09:25 PM
Saw C10FSH sliding compound miter saw kp91 Hitachi Manuals 6 03-28-2011 08:08 AM
For Sale: Ridgid 12" sliding miter saw - USED, works dovetail_65 Woodworking Classifieds 11 01-20-2011 11:28 PM
Bosch 5412L 12" Dual Compound Sliding Miter Saw and T4B Folding Stand Combo CanuckGal Tool Reviews 8 07-24-2009 01:19 PM
