Delta Band Saw Parts - Router Forums
post #1 of 27 (permalink) Old 03-20-2013, 12:21 PM Thread Starter
First Name: Ben
Default Delta Band Saw Parts
I have a 9" Delta Band saw Model 28-150. I over tightened the blade breaking the tension bracket (Part 1341597). I've searched the internet for a replacement part with no luck. The part is listed as obsolete with no mention of a replacement part.
Does anyone know of a source for this tension bracket.
Regards
Ben
Forest Reduction Study Group
Ben in Cypress Texas is offline
post #2 of 27 (permalink) Old 03-20-2013, 02:37 PM
Start calling individual Delta service centers, there may be one still around or a tech might know of a work-around.
HTH,
Bill
billg71 is offline
post #3 of 27 (permalink) Old 03-20-2013, 02:49 PM
First Name: Jack
Have you tried to this site ? There could be aftermarket part available too .
bosox is offline
post #4 of 27 (permalink) Old 03-20-2013, 07:33 PM Thread Starter
First Name: Ben
Thanks Jack
Renovo has accepted my order. It's a 'back order' but it's the first source that I'm aware of.
Thanks again
Ben
post #5 of 27 (permalink) Old 03-21-2013, 08:59 AM
First Name: Gene
Well I broke mine but it is a 14 inch delta and I got one that will to brake at least not so easy from Iturra Design email at [email protected] phone 1866 883 8064 I got one made out of steel . Gene
Genel41 is offline
post #6 of 27 (permalink) Old 03-21-2013, 10:12 AM
First Name: Duane
Originally Posted by Ben in Cypress Texas View Post
Thanks Jack
Thanks again
Ben
No longer available, and back ordered? Good luck. If you have a friend with a machine shop, I don't think it would be that hard to make one.
I have one of those bandsaws and had the same issue several years ago. Makes me wish I had ordered 2 when they were still available! Probably sell it for parts or trash it, if it breaks again!
Dmeadows is offline
post #7 of 27 (permalink) Old 03-21-2013, 11:13 AM
MikeMa's Avatar
I had that same band saw, and the exact same thing happened. The piece of metal that broke was very soft and not very strong.
I ended up replacing the band saw with a 14" Grizzly. Looks like you found a replacement part, for the Delta. I would STRONGLY recommend detensioning the blade after each day of usage to keep the strain off that piece.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #8 of 27 (permalink) Old 03-21-2013, 01:32 PM
First Name: Jack
Thanks Jack
Thanks again
Ben
I suspect if they can provide the part that soon.
NiceG316 , would that really work? I de-tension my blade because I know that it could lengthen blade life and lessen the chance of breaking blades. Leaving the blade under tension would weaken the tension spring.
bosox is offline
post #9 of 27 (permalink) Old 03-22-2013, 07:43 AM
First Name: del
This part is compatible with the following machines:
Delta
BS100 Type 1 Band Saw
SM400 Type 1 Band Saw
28-150 Type 1 Band Saw
28-150 Type 2 Band Saw
you mite check at here with the above model numbers for the part , good luck Delta BS100 Parts List and Diagram - Type 1 : eReplacementParts.com
del schisler
port st. lucie, florida
del schisler is offline
post #10 of 27 (permalink) Old 03-22-2013, 08:44 AM
First Name: Duane
Only tells us the same thing... Obsolete not available!
Dmeadows is offline
BobCAD CAM User Feed Back aldepoalo CNC Routing 33 07-13-2015 02:27 AM
Used router Missing Parts tkleff General Routing 3 02-13-2012 12:27 AM
Wanted: Parts for Delta 40-650 snowpuk Woodworking Classifieds 0 10-31-2011 09:47 AM
router parts search joromu55 General Routing 3 06-26-2008 08:58 PM
