Bosch 4100 Dado Blade Set? - Router Forums
post #1 of 8 (permalink) Old 04-03-2013, 07:29 AM Thread Starter
First Name: Keith
Default Bosch 4100 Dado Blade Set?
I would like to get a Dado Blade set for my Bosch 4100. I have searched for recommendations on size and can't seem to find a consensus. Should i go with a 6" or 8"? And any recommendations on good value for the money?
I do have the Dado blade insert for the saw on order.
kjackson82 is offline
post #2 of 8 (permalink) Old 04-03-2013, 08:07 AM
I have the Bosch 4100 and use the Freud SD208 dado set, bought from Amazon. That dado set has been flawless for me. Perfect splinter free crosscut dados in plywood and walnut.
The price difference between the SD208 8" set and SD206 6" set is only $3 on Amazon so take your pick. The 8" set is a quiet running dado.
I also have the dado insert for the saw but I don't use it, I make my own zero clearance inserts. My main go-to dado width is 1/2" so I have a dedicated insert for that.
Something to consider with our saw is that getting a full 3/4" set stacked on the arbor doesn't work (won't fit) as is with the washers from the saw and from the Bosch dado insert set (a thinner washer is provided). The arbor has a small radius on the inside edge. The normal thick washers have a chamfer to fit over that radius. The thinner washer from Bosch dado insert set does not have the chamfer. I haven't retrofitted a washer yet to fit over that spot on the inner edge of the arbor. Just a quirk of the design. Easiest way to overcome that is to take a metal file to the inside of the washer and chamfer off the needed clearance on the thin washer.
bnaboatbuilder is offline
post #3 of 8 (permalink) Old 04-03-2013, 08:07 AM
GulfcoastGuy's Avatar
First Name: Patrick
I don't own one yet but my research seems to indicate that unless you intend to cut very deep dados that the 6 inch is best for that class of saw (I own the Ridgid competition saw R4510). Less strain on the less powerful motor. I been looking at these.
Oshlun SDS-0630 6-Inch 30 Tooth Stack Dado Set with 5/8-Inch Arbor - Amazon.com
Freud SD206 6-Inch Professional Dado - Amazon.com
GCG
GCG
___
"I was always afraid of dying. Always. It was my fear that made me learn everything I could about my airplane and my emergency equipment, and kept me flying respectful of my machine and always alert in the cockpit. " - Chuck Yeager
___
http://www.routerforums.com/table-mo...table-saw.html
GulfcoastGuy is offline
post #4 of 8 (permalink) Old 04-03-2013, 05:23 PM
I use the Freud 6" dado on my 4100...
works fine...
no complaints...
post #5 of 8 (permalink) Old 04-03-2013, 07:50 PM
First Name: Earl
I've got a very good 6" set, would give me up to a 1 1/4" dado depth but i don't think i've ever gone deeper than 1/2" or 3/4" at most. I also have a cheap 8" set that i use every now and then to do half-laps in 4 x 4's. The 6" spins up easier and offers a much nicer cut than the 8" (it's a much nicer set).
The 6" is my preference by far--but the 8" has a purpose. Since it's limited purpose and use FOR ME, and framing type work when i do use it, i didn't invest much in it.
The real question--what will YOU do with it?? Dados in anything up to 2 x stock--6" will work. Some saws (Ryobi BT3000 and BT3100 come to mind) can't cut as wide with an 8" stack due to clearance issues. What's your saw's manual tell you?
earl
greenacres2 is offline
post #6 of 8 (permalink) Old 04-04-2013, 06:50 AM
First Name: Roger
I use the Freud SD306 on my Bosch, with no problems.
If using more than 1/2" though, the outer arbor washer is used as the inner washer and a special thin washer is used for the outer. That keeps things spaced right on the arbor.
Also, be careful when using the 1/16" chipper as it will drop into the threads if you're not careful. DAMHIKT.
Do as you always do,,, Get what you always get
rcp612 is offline
post #7 of 8 (permalink) Old 04-06-2013, 12:13 AM Thread Starter
First Name: Keith
Where do you get the special thin washer for the outside?
post #8 of 8 (permalink) Old 04-06-2013, 07:43 AM
First Name: Roger
It comes with the Bosch dado insert #TS1007.
But, now they are saying that you don't even need an outer washer for dado stacks over 1/2". Just use the original outer washer as the inner, set the stack up, and just add the arbor nut.
rcp612 is offline
Compound Angled Box Joints DHB Jigs and Fixtures 122 07-06-2013 04:48 AM
7" Dado blade on a 10" Table Saw?? JudgeMike Starting Off 18 12-02-2012 08:22 PM
Can Zero Tolerance Insert Be Routed Jerry Bowen Tools and Woodworking 13 11-11-2012 08:41 AM
RouterForums.com - 2008 Holiday Contest Mark Contests Archive 36 01-25-2009 02:30 PM
I think I settled on a starter bit set. Any C&C? Skyglider Router Bits - Types and Usage 40 12-28-2008 09:23 PM
