how to prevent scalloped surface with bandsaw - Router Forums
post #1 of 4 (permalink) Old 04-06-2013, 12:00 PM Thread Starter
Default how to prevent scalloped surface with bandsaw
I prefer to cut Cellular PVC with my good Delta bandsaw rather than my cheap and dangerous table saw. However, despite my best attempts at keeping my feed steady, the finish cut has the scalloped look from the blade/feed. Currently, I am using an 8 tooth, .25 blade( from Lowes, I think it's a Bosch) that cuts like butter. In the past, wider blades burned wood and cut poorly. Should I go with more teeth,same width, or same number teeth but wider blade width for a smoother, cleaner surface.
I am cutting 1/8" thin strips, so I realize that there very little room for error.
I am ,however, happy with the finish. It's all jigged, so there little slop when I am cutting. I think there's room for improvement,though, thus my question.
tony
flyforever is offline
post #2 of 4 (permalink) Old 04-06-2013, 07:19 PM
A couple options, a blade with even higher tooth count can smooth out the cut, 12-15 tpi at least.
Other method which would give perfect cuts is to build a table saw crosscut sled. I don't know how I used to build some things "in the old days", now after using a sled, smooth, repeatable and very safe cuts, perfect for small items too.
bnaboatbuilder is offline
post #3 of 4 (permalink) Old 04-06-2013, 08:04 PM
AxlMyk's Avatar
Some have smashed the blade teeth in a vise to make a thinner kerf.
AxlMyk is offline
post #4 of 4 (permalink) Old 04-08-2013, 11:10 AM
First Name: Jack
A good and right band saw blade should leave an even surface. I will get a quality blade and hope for the best.
If you are cutting a lot of thin material like 1/8" , then a high TPI number is appropriate. Check the instructions/manual of your band saw of what is a right blade width to be used.
bosox is offline
Would our academic members like to comment harrysin Lobby 2096 01-30-2015 01:54 PM
Bandsaw Economics Of Cutting Rough Timber Gaia Tools and Woodworking 22 07-13-2012 06:40 PM
Looking at buying a bandsaw... frootloops Tools and Woodworking 5 06-22-2009 09:47 AM
Grizzly GO636X 17" Ultimate Bandsaw GoonMan Tool Reviews 1 07-27-2008 02:22 AM
