Rebuilding Sander Housing - Router Forums
post #1 of 6 (permalink) Old 04-18-2013, 07:34 PM Thread Starter
First Name: Larry
Default Rebuilding Sander Housing
I need to rebuild part of a sander housing where the bearing sets. What tipe of Epoxy should I use?
woodie26 is offline
post #2 of 6 (permalink) Old 04-18-2013, 11:00 PM
You probably want to use a metalized epoxy like Belzona, JB Weld, or PC-11.
post #3 of 6 (permalink) Old 04-19-2013, 05:06 AM
First Name: Ellery
Larry,
Your biggest concern may be concentricity. If the bearing fit is gone, that could be a problem. Belzona is a great epoxy. If you can use the old bearing on the shaft, put the belzona in the housing. Coat the OD of the bearing with a LPS-3 or equivalent coating.
Assemble the sander, let the epoxy set. The epoxy will not adhere to the bearing, and it will give you a good bearing fit with no machining required. Just a suggestion, if it can apply to your fix. We have used this method for years on horizontal split case pumps with
good results. I hope this will help.
Ellery Becnel
Arcola60 is offline
post #4 of 6 (permalink) Old 04-19-2013, 09:07 AM Thread Starter
First Name: Larry
The Housing is made of Plastic.
woodie26 is offline
post #5 of 6 (permalink) Old 04-19-2013, 09:15 AM
Check out InstaMorph - Moldable Plastic, it's cheap and might be usable for this repair.
Roloff is offline
post #6 of 6 (permalink) Old 04-19-2013, 10:46 PM
Those epoxies mentioned will stick to many plastics. I bought the PC 11 because there was a glass pop bottle with a golf ball glued to the mouth at the display.
Which sander should I choose? volunteers Tools and Woodworking 63 03-02-2020 04:05 PM
Ridgid Belt/spindle sander EB4424 kp91 Tool Reviews 18 04-28-2015 10:06 PM
Belt Sander switch jph66 Tools and Woodworking 13 07-30-2012 12:41 PM
Sander question reikimaster Tools and Woodworking 11 07-14-2011 03:23 PM
My Sander Arrived!... challagan Tools and Woodworking 9 04-26-2007 09:50 PM
