metal detector - Router Forums
post #1 of 8 (permalink) Old 04-29-2013, 09:12 PM Thread Starter
First Name: ken
Question metal detector
any advice on the best metal detector to find nails and staples in wood before planing or cutting
kt6762 is offline
post #2 of 8 (permalink) Old 04-29-2013, 09:40 PM
eccentrictinkerer's Avatar
First Name: J.D.
I use this one from Harbor 'Fright' ;-) . It does the trick, it's cheap and my grandson used it last Halloween when he dressed up as a TSA agent.
they have a cheaper version, also.
eccentrictinkerer is offline
post #3 of 8 (permalink) Old 04-29-2013, 09:52 PM
Exclamation
I have a similar one made by Garrett.
Sydney, Australia
jw2170 is offline
post #4 of 8 (permalink) Old 04-29-2013, 10:14 PM
TinyTiger's Avatar
First Name: Russ
+1 on the Garrett. It works really well.
TinyTiger is offline
post #5 of 8 (permalink) Old 04-30-2013, 06:02 AM
me5269's Avatar
First Name: Michael
Send a message via AIM to me5269
Little Wizard's I got were pc's of junk.
- Mike
me5269 is offline
post #6 of 8 (permalink) Old 04-30-2013, 06:39 AM
I use a Garrett and it has always worked for me.
flockshot is offline
post #7 of 8 (permalink) Old 04-30-2013, 08:13 AM
??? Hi Mike - Mine works pretty well, picks up buried 23 guage pins consistently. Also picks out drywall screw heads under 3/4" OSB. Key seemed to be getting the sensitivity adjusted correctly. What kind of problems were you having?
John Schaben
jschaben is offline
post #8 of 8 (permalink) Old 05-06-2013, 05:38 AM
me5269's Avatar
First Name: Michael
John,
I was making a project out of skid wood. I did play with the sensitivity setting but getting inconsistent results. I randomly shot 23 ga. pins, 16 ga. brads into the top and sides of a 2x4 at different depths to try and set it. Still could not set it to pick up most of them.
I may have just had a bad unit. I ended up using epoxy to attach a rare earth magnet on a 12" 1/4" square dowel. Balance it on my finger and run it around the wood (both sides). Worked good but VERY slow.
I may give one another try in the future.
- Mike
me5269 is offline
Painting Metal dask Tools and Woodworking 9 06-26-2012 05:56 AM
Metal detectors istracpsboss Tools and Woodworking 14 05-04-2010 10:43 AM
Metal bandsaw for woodworking DerekO Tools and Woodworking 2 03-17-2010 02:33 PM
Metal Detector Clamps Mike Wingate Show N' Tell 3 10-27-2009 06:41 PM
