Drill Press Table Lift - Router Forums
post #1 of 12 (permalink) Old 05-03-2013, 08:47 AM Thread Starter
First Name: Gene
Default Drill Press Table Lift
Good Morning All,
I have a older Craftsman Floor model drill press. Problem being, it has not got the crank to raise the table and was never set up with one. It is a large cast table, it is easy enough to let it down. But getting it back up. Have any of you had this problem and how have they fixed it ? I've thought of using a long ram jack. Then to attach it is something that has been something I have not been able to solve. Thanks for any help I can get.
LiLRdWgn is offline
post #2 of 12 (permalink) Old 05-03-2013, 12:46 PM
First Name: Earl
If it were me, i'd first check here:Craftsman Drill Press Parts : eReplacementParts.com
I'd figure out what was missing, if they didn't have it for my drill press, i'd work at finding a similar c-man model and call ereplacement parts to see what might interchange. Might be cheaper than dedicating a jack to it.
earl
greenacres2 is offline
post #3 of 12 (permalink) Old 05-03-2013, 01:25 PM
Originally Posted by LiLRdWgn View Post
Good Morning All,
add a flat strap ratcheting crank handle winch like you find on boat trailers and the like...
10 bucks.. HF...
post #4 of 12 (permalink) Old 05-04-2013, 06:12 AM Thread Starter
First Name: Gene
10 bucks.. HF...
Thank You Stick, I'll have to look at that idea.
LiLRdWgn is offline
post #5 of 12 (permalink) Old 05-04-2013, 07:19 AM
IC31's Avatar
First Name: Dave W
Another way to consider as a table lift is to use an Acme threaded rod and nut, or even just a very inexpensive threaded rod and nut - McMaster Carr have about all you might need and I recommend as their rod materials are a lot better then the local hardware/big box stores McMaster-Carr. Of course, nothing is inexpensive any longer.
Dave W
Quando omni flunkus, moritati (When all else fails, play dead - R Green)
IC31 is online now
post #6 of 12 (permalink) Old 05-04-2013, 07:20 AM
Nickp's Avatar
First Name: Nick
Good Morning All,
It might be worth it to get something like this...maybe one of these made for another model and installed on yours...?
Nickp is offline
post #7 of 12 (permalink) Old 05-04-2013, 08:12 AM
First Name: Bob
Gene, there are various links on google describing a pulley /cable system using a counterweight which rides up and down inside the support column. The rise and fall of the table is easily achieved by hand with little effort.
bwiseman is offline
post #8 of 12 (permalink) Old 05-04-2013, 08:55 AM Thread Starter
First Name: Gene
Thanks for the help guys. You have given me a lot of ideas to think about.
LiLRdWgn is offline
post #9 of 12 (permalink) Old 05-04-2013, 04:23 PM
First Name: Browne
I have used a pulley and cable system and the springs from an overhead garage door to solve this problem in the past.
elrodqfudp is offline
post #10 of 12 (permalink) Old 05-04-2013, 06:26 PM
I feel your pain. I have an Craftsman drill press with the T-slot table that was almost impossible to raise (it lowered just fine!). Sears made a lift for this that I bought around 1982 that works very well. Not sure where you might find one today but well worth looking.
Name:	Drill Press Table Lift 001.jpg
Name:	Drill Press Table Lift 002.jpg
senebraskaee is offline
Simple drill press table jigs Mike Tools and Woodworking 15 04-26-2014 01:33 PM
Drill Press Dust Control Gaffboat Jigs and Fixtures 19 07-26-2012 02:29 PM
The most pitiful drill press table you have seen in a long time ... Chris Curl Project Plans and How To 19 04-17-2012 09:30 PM
Mast R Lift II on an Incra Router Table Petellie Table-mounted Routing 1 11-07-2011 06:31 PM
All thread for router skiis rstermer Jigs and Fixtures 99 08-09-2009 10:54 AM
