Thinking of making a combi-machine - Router Forums
post #1 of 3 (permalink) Old 05-07-2013, 02:12 PM Thread Starter
Default Thinking of making a combi-machine
hey guys, so my workshop is pretty small and I keep on having to move things around quite a bit.
I recently bought a DW745 table saw with it's portable stand which is great however the stand legs do take quite a bit of surface area.
This is great when you're on site because it makes the saw rock solid however in the shop it's a bit of an issue. I will also be getting a small benchtop planer this week an ELU 1901 model and I am in the process of making a router table at an approcimate size of an 700 x 900.
I also have a Axminster hobby series belt and disc sander and a small SIP bin type extractor.
Rather than having these objects taking up static space I was considering making a whole cabinet on caster wheels which will house all of these.
I also do not have a workbench so I thought this would be a good opportunity to somehow use this unit as a workbench somehow..
I attached an image of what i think the plan will look like.
However my thoughts are that I have never seen a shop made Router/Table Saw/Planer thicknesser setup in one jig.
Has anyone got any pics of links of similar setups?
Is this not advisable to do?
Could I somehow use the same fence for the Router + Table Saw + Planer + Possibly belt sander?
If I rig up a static hose system for dust collection will I need a higher dust extractor than my 1.5HP SIP extractor due to distance travelled or split hoses?
What wood surface should I use overall? Laminated Plywood?
And as far as the base of this entire unit is concerned how thick do you think the timber battons need to be to carry all this weight?
Many thanks to any input you may have
mouchmouch is offline
post #2 of 3 (permalink) Old 05-07-2013, 03:23 PM
boogalee's Avatar
First Name: Al
Hi N/a
Here is a link to a miter saw / planer setup on youtube
miter/planer table
I am sure you could modify it for your needs. He also includes a sketchup drawing link in the comments.
Al
boogalee is offline
post #3 of 3 (permalink) Old 05-07-2013, 04:39 PM
Gene Howe's Avatar
First Name: Gene
Shopsmith?
Gene Howe
Snowflake, AZ
Gene Howe is online now
sewing machine cabinet for SWMBO dick in ia Show N' Tell 7 12-12-2012 06:23 PM
Pachinko Machine kp91 KP91's gallery 11 03-10-2012 10:15 PM
Cabinets with minimal tools - Making do... reikimaster Tools and Woodworking 31 02-08-2012 05:30 PM
CNCrouterparts 4X4 R&P machine assembled in 9 hours bloomingtonmike CNC Routing 3 02-02-2012 06:36 PM
sewing machine reible Portable Routing 16 02-23-2006 12:00 PM
