Table Saw mobile base suggestions - Router Forums
post #1 of 22 (permalink) Old 05-11-2013, 07:41 AM Thread Starter
First Name: Dave
Question Table Saw mobile base suggestions
I could move my old table saw around at will with no problem to use it and then slide it back out of the way. Recently I was very fortunate to obtain a very large, very heavy table saw from one of the members here. I am looking for mobility solutions. It's base is the typical fixed leg contractor's saw, 10 inch. Any suggestions or thoughts? Thanks in advance, Dave
adot45 is offline
post #2 of 22 (permalink) Old 05-11-2013, 08:34 AM
Dave, I like my HTC mobile bases. They are inexpensive and work well.
post #3 of 22 (permalink) Old 05-11-2013, 11:34 AM Thread Starter
First Name: Dave
Hi Mike, Thanks for the suggestion of the HTC base. One thing I notice about these bases, and all platform type units for that matter, is that getting the table saw up and on them would take some doing....I do like the fact that they don't raise the working height by much. I am looking at the HTC2000 that adjusts up to 36" x 36". I should have had this figured out before I put the saw back together.....
adot45 is offline
post #4 of 22 (permalink) Old 05-11-2013, 11:48 AM
First Name: Earl
+1 on HTC. I also have Shop Fox under my planer, and am quite pleased with it as well.
Earl
greenacres2 is offline
post #5 of 22 (permalink) Old 05-11-2013, 02:58 PM
TinyTiger's Avatar
First Name: Russ
I also have a Shop Fox under my saw that works well.
TinyTiger is offline
post #6 of 22 (permalink) Old 05-11-2013, 04:43 PM Thread Starter
First Name: Dave
Thank You Earl and Russ, I appreciate your input.
adot45 is offline
post #7 of 22 (permalink) Old 05-12-2013, 05:18 AM
First Name: Dick
Dave I also use the HTC 2000 under my old Grizzly saw. My saw is pretty heavy with the cast iron wings but my son and a friend lifted it while I slid the base under it.
Where there's a Willis there's a way!
Willway is offline
post #8 of 22 (permalink) Old 05-12-2013, 09:23 AM
First Name: Barry
Dave, I'm not sure how big the footprint of your saw is or how heavy it is but if you're interested in the Shop Fox heavy duty base (holds 700 Lbs, go from roughly 20"x20" to almost 30"x30") Grizzly has it on sale for under $60. D2057A Heavy-Duty Mobile Base. I do not have this base but i'm considering it for a band saw.
Barry747 is offline
post #9 of 22 (permalink) Old 05-12-2013, 09:37 AM Thread Starter
First Name: Dave
Thank You Dick for your input.
Barry, that is certainly worth and look and consideration. Thank you for the tip.
adot45 is offline
post #10 of 22 (permalink) Old 05-12-2013, 12:38 PM
First Name: Bruce
I have the Grizzly D2057A and the directions show how to build the stand underneath the saw and you lift on side at a time as you build it. So no lifting the saw up all at once. You could use their directions on any type of mobile base, just download the instructions from Grizzly's WEB Site.
CAD-Man
CAD-Man is offline
mobile base for my ts from scrap trojan62 Show N' Tell 2 07-19-2012 04:42 AM
Construct a base for square 140x140 cm glass top dinner table Benito New Member Introductions 7 06-26-2012 05:26 AM
How to Make a Table Base learnexperience Tools and Woodworking 0 08-11-2011 10:40 PM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
