Thicknessing vs. Planing - Router Forums
post #1 of 6 (permalink) Old 05-14-2013, 07:56 AM Thread Starter
First Name: Sonny
Default Thicknessing vs. Planing
A few weeks ago I stumbled across the website Woodgears (woodgears dot ca) and found plans for a thickness sander. Since then, I have seen a few references to "thicknessing" wood. So, my question is, what is the difference between "thicknessing" and planing wood? Aside from the obvious that one method sands the stock down to a certain thickness and the other cuts... I am wondering if there is a difference in the end result. If, in general, one method is preferred over the other.
Tumbler is offline
post #2 of 6 (permalink) Old 05-14-2013, 08:25 AM
Honored Member
First Name: pat
Thickness = verb, to render a stick uniform in thickness = planing or sanding. Can be done x hand but usually done in a machine that produces a stick of constant thickness.
Material prep.
Quillman is offline
post #3 of 6 (permalink) Old 05-15-2013, 11:06 AM
MikeMa's Avatar
Also, in other parts of the world, what we in the U.S. call a planer is known as a thicknesser, and what we call a jointer is referred to as a planer. So when someone says they are thicknessing wood, it is the same as saying planing wood down.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #4 of 6 (permalink) Old 05-15-2013, 11:28 AM
curiousgeorge's Avatar
First Name: George
The main difference is that the planer will leave a relatively smooth surface but will need further sanding to give a finished surface and it is able to remove a fair amount of thickness per pass. Where as with the "sander" thicknesser you can achieve a finished surface from the start but, it takes longer because it only removes very small amounts per pass. I guess it depends on what you are wanting to accomplish and can afford. Some shops have both machines.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #5 of 6 (permalink) Old 05-16-2013, 03:06 PM Thread Starter
First Name: Sonny
I wanted to assume they were pretty much the same, however, I have only ever seen and used a planer a planer (with blades) and didn't realize there were other methods. Since I had never seen a thickness sander I wasn't sure if there was (is) any benefit to that way of planing/sanding stock down.
Thank you to everyone of the input. I am much the wiser for it.
Tumbler is offline
post #6 of 6 (permalink) Old 05-16-2013, 03:17 PM
Honored Member
First Name: pat
Major benefit to thickness sanding: Zero tearout.
Major detriment: Most sanded surfaces need more sanding after thickness sanding.
If there is no vibration, the feed exact and uniform, the paper is new:
Then finish quality sanding can be realized from a thickness sanding tool.
Quillman is offline
Planing with a Router Gilbear Portable Routing 51 05-17-2012 04:40 PM
what hp for router thickness planing using skis tomcoleman Jigs and Fixtures 7 04-02-2012 04:52 PM
First router suggestions (for thickness planing and cabinetry) bokubob General Routing 13 10-17-2011 09:22 AM
New To Forum - Building a Planing Sled Burkdb New Member Introductions 4 11-11-2010 03:30 PM
I need help with planing mcdonelldj Tools and Woodworking 22 07-26-2010 03:10 AM
