Has Anybody Tried The Big Gulp? - Router Forums
post #1 of 11 (permalink) Old 05-14-2013, 01:56 PM Thread Starter
First Name: Jerry
Default Has Anybody Tried The Big Gulp?
One of the members of this forum has put put me on to product called "The Big Gulp" and is available through Rockler. I'm wondering if anybody has attempted to install this item in the cabinet of their TS and if so how it has worked for them.
It does not appear from the photo that it is configured in a manner that would alloe it to be installed in the cabinet, but since I am not sure is why I am asking.
Jerry
Jerry Bowen is offline
post #2 of 11 (permalink) Old 05-14-2013, 03:36 PM
Jerry, I use one with my mini lathe and it works great. It could be adapted to work on a table saw.
post #3 of 11 (permalink) Old 05-14-2013, 03:51 PM
Marcel M's Avatar
First Name: Marcel
Talking
Yup, but usually around mid summer. The Super Big Gulp is quite refreshing as well.
Marcel M is offline
post #4 of 11 (permalink) Old 05-14-2013, 06:06 PM Thread Starter
First Name: Jerry
Mercel,
I asked for it didn't I. I knew that when I started this thread that the tempation for a reply like your's would just to great to resist. Thank goodness for our ability to laugh and find humor in our lives from time to toem, I sort of see how they would call the item what they did, but it a bit strange.
Jerry
post #5 of 11 (permalink) Old 05-14-2013, 06:26 PM
Marcel M's Avatar
First Name: Marcel
Originally Posted by Jerry Bowen View Post
Mercel,
Jerry
I couldn't restrain myself.
Marcel M is offline
post #6 of 11 (permalink) Old 05-14-2013, 06:58 PM Thread Starter
First Name: Jerry
Mike,
By adapted, I assume that you mean modified by the end user which may or may not be a big hassle. Thanks for your response. After drilling the holes in the insert most of the problem with the DC are solved, just looks like the Big Gulp might be the iceing on the cake in regard keeping the dust almost completely from accumulating in the cabinet, think I'll give it a try and see what happens.
Jerry
post #7 of 11 (permalink) Old 05-14-2013, 08:38 PM
First Name: Earl
Looks a lot like the collection funnel in the bottom of my Craftsman 21833. And, if i recall correctly from looking at the manuals when i was shopping, the Ridgid R4512 uses something similar as well. Mounts between the "cabinet" and the leg assembly, porting through the bottom. Seems pretty functional.
I don't recall your saw Jerry, but on a contractor or hybrid seems that it would be as simple as cutting a sheet of aluminum to the dimensions of the leg assembly, then cutting an opening for the Big Gulp and riveting. Punch holes to mount the saw and you'd be in business.
I could also see suspending one just above and in my case slightly to the front of the blade--might capture some of the "whiskers" i get when ripping.
earl
greenacres2 is offline
post #8 of 11 (permalink) Old 05-14-2013, 09:34 PM
If you are talking about the one below
http://www.rockler.com/product.cfm?p...2&site=ROCKLER
I put one on my planer and worked out great.
post #9 of 11 (permalink) Old 05-15-2013, 11:18 AM
MEBCWD's Avatar
It works good for a radial arm saw. I also clamp one on a stand where I am using a hand held router and it catches quite a bit of the dust and chips.
MEBCWD is offline
post #10 of 11 (permalink) Old 05-15-2013, 11:45 AM
First Name: Dave
Penn State has it (Big Gulp) on sale right now for $15.95.
adot45 is offline
Using two touch plates and the Mach Blue Big Tex screen with Mach bloomingtonmike CNC Routing 0 02-07-2012 02:32 PM
Big Cherry BernieW Woodturning and Lathes 6 07-05-2010 11:01 PM
How big is a 2 1/4 hp base? Noob Table-mounted Routing 3 04-28-2009 02:00 PM
A Big Snowman.... challagan Pyrography and Carving 12 09-05-2008 07:03 PM
Big Funnel BernieW Woodturning and Lathes 7 08-17-2008 12:18 AM
