drill press chuck taper - Router Forums
post #1 of 6 (permalink) Old 05-19-2013, 07:12 PM Thread Starter
First Name: Al
Default drill press chuck taper
I have a delta 11-990 drill press with a trashed chuck. I need to know the taper of the chuck so I can order a new one.anyone know?
al m is offline
post #2 of 6 (permalink) Old 05-19-2013, 07:38 PM
It should be stamped on the chuck
Amazon.com: drill press chuck: Tools & Home Improvement
post #3 of 6 (permalink) Old 05-19-2013, 07:57 PM
IC31's Avatar
First Name: Dave W
I will guess that it's a #2 MT based on mine, where I worked many years ago as well as other similar drill presses in the 1/2" chuck range that I've seen.
Here's a WIKIPEDIA write up - measure what you have: Machine taper - Wikipedia, the free encyclopedia
Dave W
Quando omni flunkus, moritati (When all else fails, play dead - R Green)
IC31 is offline
post #4 of 6 (permalink) Old 05-20-2013, 06:13 AM
First Name: Richard
Send a message via Skype™ to rwbaker
go to Makita Parts | Hitachi Parts | Dewalt Parts | Repair Parts | Replacement Parts, Delta, etc and look at the parts schematic for your drill (I just did), the spindle unlike others appears to have a taper at the chuck, but not the upper spindle? The chuck end is likely to be a JT33 or JT3 (Jacobs Taper). The upper spindle is usually a MT1, 2,3,4,5 - with Morris taper 2 being the most common. Call Delta and they will tell you - the drawings and schematics appear to be un-specified. turn the front pulley by hand as from the schematic the spindle also travels, in one piece, through the forward pulley. not a typical arraignment. If the spindle turns, good. If he spindle does not turn then you need a lot more parts.
Good luck,
Baker
rwbaker is offline
post #5 of 6 (permalink) Old 05-20-2013, 05:06 PM Thread Starter
First Name: Al
The chuck is not clearly marked,but it may be a 33,just want to be sure before I order a replacement. the taper is at the chuck,with the female end being the chuck and the male at the spindle,opposite of what I have seen in the past.Experiance tells me it is most likely not a morris taper.I did look at the online parts diagrams and did google search for answers before posting here.
AL
al m is offline
post #6 of 6 (permalink) Old 05-20-2013, 05:53 PM
AL
If it's a JT 33 taper, I can hook you up with a real nice keyless for half the MSC price. PM me if you're interested. You really haven't lived until you've used a keyless chuck on a drill press, it's one of those "never going back" things.
Good luck,
Bill
billg71 is offline
Drill DP15501 15" Drill Press allthunbs Ridgid Manuals 2 01-18-2018 12:13 AM
Chuck in Drill press keeping coming loose Kelly Rittgers Tools and Woodworking 9 01-12-2011 06:29 AM
Removing taper from drill chuck old gizmo Tools and Woodworking 2 09-07-2010 08:55 PM
All thread for router skiis rstermer Jigs and Fixtures 99 08-09-2009 10:54 AM
drill press chuck levon Tools and Woodworking 29 06-08-2009 12:31 PM
