Drill press recommendation - Router Forums
post #1 of 63 (permalink) Old 06-03-2013, 08:24 AM Thread Starter
boogalee's Avatar
First Name: Al
Default Drill press recommendation
I am looking for a floor model variable speed drill press. Would appreciate any recommendations.
Thank
Al
boogalee is online now
post #2 of 63 (permalink) Old 06-03-2013, 11:28 AM
MikeMa's Avatar
I have a 20+ year old grizzly that I received a couple years ago. I cleaned it up, and it works great. Grizzly has a pretty good line of drill presses.
One thing I will point out, is most drill presses are designed around metal working, and the tables really aren't designed well for woodworking. This is why you see so many plans for DP tables out on the Internet. There are two companies that make drill presses that really are geared towards woodworking with really nice tables that I believe can accept inserts to help prevent tear-out when drilling. One comes from Delta, which I am sure is a decent machine. However, Delta was recently bought by a new company and has been experiencing significant growing pains, so you may want to factor that into a purchase decision. Powermatic also makes a very nice drill press, and the company is on a much more solid footing right now. Both the Delta and Powermatic drill presses are expensive when compared to Grizzly and other brand drill presses.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #3 of 63 (permalink) Old 06-03-2013, 11:34 AM Thread Starter
boogalee's Avatar
First Name: Al
Thanks Mike
I have a few Grizzly machines and have been pleased. When I checked Grizzly they only showed 5 and 12 speed presses(not variable).
Al
post #4 of 63 (permalink) Old 06-03-2013, 03:50 PM
Al; mine's a JET and I like it well enough but as Mike (G316) suggested it's not perfect for woodworking. The two things that I would keep in mind is the depth of vertical movement (stroke), and the horizontal clearance to the column (swing). Those are both major limiting factors.
I might also add that although I certainly don't have a better design in mind, I really dislike the ergonomic limitation of the spoke type stroke handle (proper name?). I can't get a full downstroke without having to re-position my hand part way down. I think a steering wheel with a knob might be more user friendly; any thoughts?
DaninVan is online now
post #5 of 63 (permalink) Old 06-03-2013, 04:14 PM
I got my Jet in 1960 and it's great drill press it's the older type painted Green but has given many years of service and I still use it all the time..
post #6 of 63 (permalink) Old 06-03-2013, 04:24 PM
Honored Member
First Name: pat
Older (>40 years) Iron often simpler and better than the new cheap (<$1000) machines.
Rockwell, for example.
Quillman is offline
post #7 of 63 (permalink) Old 06-03-2013, 05:46 PM
I have a 15 or so year old Delta 16 1/2" and it works okay. I had to have it repaired from new. Dowels would fall out of the holes I drilled for them. I put a brad point bit in it and just touched the surface of a board and it scribed a circle that was 1/32" in diameter minimum. Out of 10 stars I would only give it about 5.
post #8 of 63 (permalink) Old 06-03-2013, 09:46 PM Thread Starter
boogalee's Avatar
First Name: Al
Dan
I checked out Jet and they are a bit pricey for a variable speed ($1200 - $4000). My limit would be about $1000.00
You could always build yourself a hand crank. I recently built one for a router lift that I built for my nephews.
Thanks for the reply.
Bob
I have checked craig's list for older machines and I have not seen any in my area. I believe old iron was manufactured at a higher standard. Guess I will keep looking.
5 out of 10 does not seem to be what I'm in the market for. LOL
Al
post #9 of 63 (permalink) Old 06-04-2013, 12:54 AM
Another place to look: Products in Floor,Machinery,Drill Presses on Wholesale Tool
post #10 of 63 (permalink) Old 06-04-2013, 07:29 AM
First Name: Earl
I like that idea Dan. When I can get back out to the shop i'm going to look at mine (1980 Chicago Machinery 13") to see how tough it would be to retrofit. One initial thought is maybe a wooden disk with a centering hub and 3 u-bolts around the existing spokes. Handle attached to wheel with lock nut and nylon washer. Where to place the handle will depend on the beginning and end of a full stroke.
earl
greenacres2 is offline
Drill DP15501 15" Drill Press allthunbs Ridgid Manuals 2 01-18-2018 12:13 AM
Picture of my Drill Press recently finished RLego Tools and Woodworking 5 07-12-2013 03:13 PM
Drill Press Table TRN_Diesel Show N' Tell 33 01-02-2013 11:46 PM
Drill PRess.. help me pick please!! woodaholic Tools and Woodworking 8 09-13-2011 10:53 PM
All thread for router skiis rstermer Jigs and Fixtures 99 08-09-2009 10:54 AM
