dado plate insert - Router Forums
post #1 of 16 (permalink) Old 06-04-2013, 09:10 PM Thread Starter
First Name: slackinone
Default dado plate insert
got a sears table saw 137.218010
in the manual it says it can handle a 6" dado set up and to make sure you use a dado insert plate, but I cant find it anywhere.
I have chatted with sears on partsdirect site. no luck.
I found one in store that is close but not quite it.
one on right is original one, one on left is the close but no cigar one
slackinone is offline
post #2 of 16 (permalink) Old 06-04-2013, 09:43 PM
TinyTiger's Avatar
First Name: Russ
Hi Slackinone! Welcome to the forum.
How thick is your original tablesaw insert? Can you make one of your own out of shop materials? It's common to make zero clearance inserts at home out of plywood, MDF, or hardboard (depending on how thick it is). You just use the original one and cut the others to fit the same size saw opening and screw pattern. That way you can save some money and get an insert that precisely fits your dado cutter. I have about a dozen for all my different widths of dado sets.
TinyTiger is offline
post #3 of 16 (permalink) Old 06-04-2013, 10:10 PM Thread Starter
not to thick, but the screaw holes have an indent and a spacer for the original.
after searching someone pointed out the real maker of the saw that sears (craftsman) put their name on.
Sears and Craftsman Source Product Code
137 Rexon
defodesign.com/tradesman_rexon/
so I'll try there , but if its too much I can try and make one
post #4 of 16 (permalink) Old 06-04-2013, 11:02 PM
GulfcoastGuy's Avatar
First Name: Patrick
+1 on that. Make your own. I just got the Oshlun 6" stack and made one from mdf. No leveling screws; used a tip from Woodsmith and set it down on some spots of hot glue, worked great.
Leveling a Table Saw Insert | Woodsmith Tips
GCG
___
"I was always afraid of dying. Always. It was my fear that made me learn everything I could about my airplane and my emergency equipment, and kept me flying respectful of my machine and always alert in the cockpit. " - Chuck Yeager
___
http://www.routerforums.com/table-mo...table-saw.html
GulfcoastGuy is offline
post #5 of 16 (permalink) Old 06-04-2013, 11:46 PM
You can't make one out of plywood or mdf, they would be way too thick. You might be able to make one out of sheet metal if you have the skills. I made one for an older Sears saw. If you can find another insert like the one you already have you should be able to cut the blade area out to fit the dado set.
post #6 of 16 (permalink) Old 06-05-2013, 12:01 AM
First Name: Dick
Hi Slackinone, I would suggest you make your own out of some kind of wood or plastic product the same thickness as your plate. Take a look at this video. Although your plate is made differently you would need to follow this same procedure. I always try to copy the same type of mechanism to hold the plate in as your old plate. Hope this helps.
MM 2-18-12: Zero clearance inserts - YouTube
Where there's a Willis there's a way!
Willway is offline
post #7 of 16 (permalink) Old 06-05-2013, 12:19 AM
MAFoElffen's Avatar
Russ and Patrick... Craftsman contractor style saw. The stock insert is pressed tin, about 1.3mm (18 gauge) sheet metal. Not even enough room there to make an insert out of thin lexan or aluminum (no strength at that thickness).
The one he has pictured on the left is model #29973, for a 113.221740 saw.
What I would do, is order an original insert plate (they're about $14.00) and cut out the relief yourself. Mark the center of a 10" blade on the insert. Then use the wrong plate's coutout to get where it needs to be cut out.
Check often and adjust to what is there. That is the easiest way to do that. Holes will then all be correct. The size will fit. And the pressed in seats will be correct.
I've got a plasma arc, air cutoffs, die grinders... But you could drill a few holes in the corners, then cut it out with a hacksaw.
Another alternate would be to make it from sheet metal. More work and would have to level it with washers. The insert would be too thin to level with set screws.
MAFoElffen is offline
post #8 of 16 (permalink) Old 06-05-2013, 10:39 PM
First Name: Dick
I didn't realize this is a stamped sheetmetal plate. Mike has the right idea on this, a new plate, a hacksaw and a file!
Willway is offline
post #9 of 16 (permalink) Old 06-06-2013, 08:44 AM
Daikusan's Avatar
Country: Japan
First Name: Steve
I have a craftsman table saw too. The plates you have in the picture look identical to mine.
I made zero clearance plates out of Plexiglas and used the router to countersink a hole on the bottom. The back side screw hole is raised 3mm to hold the original stamped plate flush with the table. After trimming everything I slowly raised the dado and let it cut its own hole. That essentially what was in the above video; I just took it a step further and rabited the bottom edges to get it flush with the table.
Workmanship is not perfection; it is how well you can cover your mistakes.
Daikusan is offline
post #10 of 16 (permalink) Old 06-06-2013, 09:35 AM
First Name: Dave
Default dado insert
I too recently got a dado set and had trouble trying to sort out Sears part numbers for a dado insert. My saw is a Sears 315. and the insert plate is nominally 1/8" and the leveling screws add another 1'8". I just used 1/4" oak plywood, cut the shape, drilled and counter sunk the set screw, put it in and set the fence down on it and raised the dado blade to make the cut. I made one for 1/2" and one for 3/4". Hope this helps.
Name:	dado insert.jpg
adot45 is offline
Samona Insert Plate bill0199 Table-mounted Routing 9 01-06-2012 02:30 PM
For Sale: Woodhaven 147 Large Insert Plate - $25 oldhippie1951 Woodworking Classifieds 0 08-16-2011 05:55 PM
Bench Dog Pro Plate and Zero Clearance Insert problem matt1710 Table-mounted Routing 24 07-17-2011 07:37 AM
Rockler large blank plate bushing insert..... Duane867 Table-mounted Routing 25 12-07-2009 06:36 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
