Product Review - Trend's Tool and Bit Cleaner. - Router Forums
post #1 of 13 (permalink) Old 06-08-2013, 07:58 AM Thread Starter
N'awlins77's Avatar
First Name: Lee
Default Product Review - Trend's Tool and Bit Cleaner.
Well let me start out by saying, I'm a changed man!! I'm the kind of person that when it comes to things like cleaning products, and the such, that's there's not much difference from one or the other. I've been cleaning my router bits, as I'm finished with them, with a product from Ashburns. We buy it by the case, at work. It's very similar to WD-40, it is a penetrating lube/cleaner. It works great on getting grease and grime off of my mechanic tools, so when I got deep into woodworking, I started cleaning my bits with the same stuff. I read Mike and others on here praise Trend's Tool and Bit Cleaner. But I figured the stuff I already had will work just as good. No reason to buy some specialty cleaner. Boy, was I wrong!! I guess cleaning bits, right after they have been used, is one thing. The sap and such hadn't had time to dry, before I cleaned it off. But I decided, when I was ordering some other things from Peachtree, and I needed a little bit more to make a decent order and came across the Trend Bit Cleaner, I figured I'd give it a try.
About a year ago I started building my own kitchen cabinets. From the advice from members here, I purchased a Freud Diablo 60 tooth blade and put on my table saw. It has never been taken off since, except for today, for the purpose of this test. So you can imagine the build up on them.
And well, after doing this review this morning, you can bet your last dollar, I'll always have some of Trends Tool and Bit cleaner at hand!! The proof is in the pictures. Now if you'll excuse me, I've got 2 more saw blades to remove and clean!! ;o)
Name:	01-Tool Cleaning Test.jpg
Name:	02-Trend Vs Penetrating Lube Cleaner.jpg
Name:	03-Penetrating Lube - Side 1.jpg
Name:	04-Trend Tool and Bit Cleaner - Side 2.jpg
Name:	05- Side by side comparison .jpg
Name:	06- Close-up of Penetrating Lube.jpg
Name:	07-Close-up of Trend Tool Cleaner.jpg
Name:	08-Entire blade cleaned with Trend.jpg
Name:	09-Close-up of clean blade - Trend.jpg
Name:	10-Close-up of clean blade - Trend.jpg
N'awlins77 is offline
post #2 of 13 (permalink) Old 06-08-2013, 10:49 AM
I got some not long ago too Lee and it really is that good and pleasant to use too. Once in a while you come across a product that really does excel at the job it is supposed to do and this is one of them.
post #3 of 13 (permalink) Old 06-08-2013, 11:20 AM
Contributor of the Month
OPG3's Avatar
First Name: Otis
Lee, Everything I've heard about this product has been positive! Keep-up the good work! I am still using a pitch and gum remover that works good, but when I am done with that bottle, you can bet I'll be getting this one (Trend) on my next Peachtree order.
Thanks for your excellent review!
OPG3
Tweak everything!
OPG3 is offline
post #4 of 13 (permalink) Old 06-08-2013, 11:23 AM
Lee, try it on a rusted tool. Spray on and let it sit for a minute or two, work it around with green ScotchBrite pad, wipe with a clean towel.
Now that you know how good this works the next step is Trend's diamond sharpening products. Do not confuse them with cheap diamond sharpening products, there is a huge difference in performance and life span. I am working on a review with photos and I think this combination is another winner.
Name:	Diamond sharpening.JPG
post #5 of 13 (permalink) Old 06-08-2013, 06:21 PM
I bought a good water stone from Lee Valley at least 15 years ago and it does a very good job. About 10 years ago I started using diamond hones and the water stone hasn't seen much use since. Even the cheap ones are good. The best thing about the diamond stones is that they stay flat. In fact, you can use the coarse ones to true up water stones that are worn. I'll be watching for your review.
post #6 of 13 (permalink) Old 06-08-2013, 08:24 PM Thread Starter
N'awlins77's Avatar
First Name: Lee
Mike, I tried it on an old pipe wrench I got from my Dad, and it probably wasn't the best thing to test on, since it has about 40 years of rust on it, but it did do pretty well on it. It didn't have that "WOW" factor that I got out of using it on my blades, but it did knock some rust off. However, I don't think it would have showed in any pictures.
After using the Trend stuff again, on the pipe wrench, it sure started to smell familiar too me. I think it smells like this citrus cleaner I have. Has the same feel to me between the fingers too. I never thought about trying the citrus stuff on the bits or blades. But that Trend cleaner definitely has a familiar smell to it.
And I tell you what, after finishing cleaning my three saw blades (table, miter and circular) I ripped a couple of boards for some trim I'm still working on for the kitchen, and I sure did feel a difference in my cut. Almost like I had the blade sharpened.
post #7 of 13 (permalink) Old 06-11-2013, 11:30 AM
First Name: Paul
Lee and everyone,
I just called my local tool shed, Syracuse Industrial Sales, and asked about the Trend product. They don't carry it but do carry the newer CMT Bit and Blade Cleaner. Have any of you been able to compare the two products? Or use them?
Thanks.
Paul
PRDarnell is offline
post #8 of 13 (permalink) Old 06-11-2013, 06:25 PM Thread Starter
N'awlins77's Avatar
First Name: Lee
Not I Paul!
But... Mike, I did give the Trend cleaner another try on some rust again. This time it was some light rust I had noticed on my scroll saw table, before I locked up for the night. I sprayed the Trend cleaner on it, let it sit for a minute, and using JUST a rag (no Scotch Bright, or anything) and it wiped the rust right off. No shadow or stain of the rust being there. Just gone! Can you buy this stuff by the gallon?? LOL Really good stuff, in my opinion!!
post #9 of 13 (permalink) Old 06-11-2013, 07:07 PM
Trend Tool and Bit cleaner is also available in 5 or 55 gallon drums. The spray bottle lasted me a year and I use it more than most people would.
Paul, the CMT product is not as good from what I have seen. You can purchase the Trend Tool and Bit cleaner from Woodcraft.com; Sommerfeld Tools and Peachtree.
post #10 of 13 (permalink) Old 06-17-2013, 02:38 PM
First Name: Paul
While waiting for my Trend Tool and Bit Cleaner to arrive I tried the CMT 2050 on an old 6.5" circular saw blade on my old 147B P-C. I use that saw for a lot of stuff just because it is fairly small and handy.
I was NOT IMPRESSED. I applied the CMT twice, waiting 10-15 minutes each time before wiping it off. There is still a small amount of residue (pine pitch?) near the base of the teeth. I haven't tried cutting with it yet. But as for application it wasn't what I hoped. It smelled something like liquid soap and didn't have any sign of lubrication or slipperiness left on the blade once I wiped it off.
When I get my Trend cleaner I'll try it on a similar blade and report back in.
Grrrr.
Trend Tool and Bit Cleaner SALE Mike The Bargain Bin 1 02-15-2013 10:02 PM
Peak HP dgcutter General Routing 22 01-10-2013 08:23 PM
Selecting the Correct Router Bit LMT Onsrud (Onsrud) Router Bits - Types and Usage 1 02-07-2012 11:17 PM
Jet Tool/ ToolSelect Review The Bench Dawg Tools and Woodworking 2 11-06-2011 08:15 AM
