Kreg jig question - Router Forums
post #1 of 18 (permalink) Old 06-23-2013, 11:01 AM Thread Starter
First Name: Greg
Default Kreg jig question
I am new to the forums and have used my Kreg pocket hole jig quite a few times. I have only used stock that is the same size for the joint. I have a project that is using two different thicknesses. 1-1/2" and 3/4". The holes are being drilled into the 1-1/2". The question is do I set the jig and bit for 1-1/2" (I think I should) and what length screw do I use?
Thanks,
Greg
greg.l is offline
post #2 of 18 (permalink) Old 06-23-2013, 02:16 PM
First Name: Clay
I think you will still keep it set for 3/4" and use 1 1/4" screws.
You could set if for 1 1/2" and go with the longer screws but you will not gain anything since you will still be putting the same amount of screw into the 3/4.
As always just set it up and do some testing before you hit the good stuff.
fire65 is offline
post #3 of 18 (permalink) Old 06-23-2013, 05:13 PM Thread Starter
First Name: Greg
Yeah, I'll test it out first. The jig instructions don't talk about mismatched sizes at all. I watched the videos as well and didn't catch any thing about it.
greg.l is offline
post #4 of 18 (permalink) Old 06-23-2013, 05:31 PM
Semipro's Avatar
First Name: John_*
Greg
When you are working with two different thicknesses you will want to set everything up and use the screw length for the thinner thickness of the two. For example if you are drilling your holes in a 2X4 and attaching it to a 3/4" piece you will want to set the jig and the depth collar for the 3/4" setting and use a 1 1/4" screws. If you are going the opposite way and drilling your holes into the 3/4" piece and joining it to the 2X4 you would set everything up the same, but you can use a little bit longer screw to give you some more strength.
Semipro is offline
post #5 of 18 (permalink) Old 06-23-2013, 06:48 PM
Exclamation
Hi Greg, welcome to the forum.
Kreg have a specific instruction to cover that. I will see if I can find it.
Screw size for DIFFERENT sized lumber - Kreg Jig Owners Community
PS: found this file hidden in the above link.
Sydney, Australia
jw2170 is offline
post #6 of 18 (permalink) Old 06-23-2013, 06:50 PM
Hi
I have 4 brands of pocket holes systems and I use 2" and 3" long screws now and then no big deal ,set it and forget it..
post #7 of 18 (permalink) Old 06-23-2013, 07:22 PM
Country: Brazil
First Name: ClŠudio
James good file.
Thank you.
Botelho007 is offline
post #8 of 18 (permalink) Old 06-23-2013, 08:46 PM
boogalee's Avatar
First Name: Al
Thanks,
Greg
kreg screw size
About 5:10 into the video he talks about different size pieces of wood.
Al
boogalee is offline
post #9 of 18 (permalink) Old 06-24-2013, 09:00 AM
Shortslvs's Avatar
First Name: Fred
James I printed that baby out and I am putting it in the box with my screws.
Seems simple enough to just figure out, but as I add up the time spent doing that - well the pdf will come in very handy
Shortslvs is offline
post #10 of 18 (permalink) Old 06-24-2013, 09:59 AM Thread Starter
First Name: Greg
Thanks James. That is exactly what I needed. The chart is going to hang off the tool chest.
greg.l is offline
Question about Kreg Levelers malargent Table-mounted Routing 5 01-04-2013 01:07 PM
Yet another dovetail jig question drbbob Jigs and Fixtures 1 01-27-2012 09:20 AM
Question about Jet Dovetail Jig kalida309 Jigs and Fixtures 5 02-16-2009 05:12 AM
Router Biscuit Bit Usage Question (jig)??? Nickbee Router Bits - Types and Usage 15 11-22-2007 10:55 PM
